Using a Texture as Skin for an IC Character Creator actor
Posted By grouchmaxweb 9 Years Ago
grouchmaxweb
grouchmaxweb
Veteran Member (565 reputation)Veteran Member (565 reputation)Veteran Member (565 reputation)Veteran Member (565 reputation)Veteran Member (565 reputation)Veteran Member (565 reputation)Veteran Member (565 reputation)Veteran Member (565 reputation)Veteran Member (565 reputation)
Last Active: 6 Years Ago
Posts: 14, Visits: 111
For example if you create your Actor and you want to add say a lizard skin texture to your character  from a phote ,how can you do that? I can get a copy of UV ref into  Photo shop to add my pattern fill to the Skin map. How can I get that back into  I clone to change the skin texture of my actor. Any pointers would be gratefully received. I have a created head in Crazy talk pro 7. It would be great if  I could use that head on my CC Actor.. Is this all possible or will I have to purchase further add ons.
Many Thanks Grouchmax .
Posts: 8.2K, Visits: 62.6K
In iClone, double-clicking on any of the texture channels lets you import an image for that texture. So, edit your new skin texture in Photoshop (or whatever) and import to the "diffuse" texture channel in iClone. Note that the head and body are separate UV's.
If your just doing a pattern fill with a repeating tile, load that tile into the diffuse channel and set its tiling accordingly. No Photoshop needed. ;)
If you have the "Essentials" pack for Character Creator, you can load your new skin there if you'd rather. It's slightly more complicated, but gives you the options of the texture Substance that CC uses. Things like decals, body hair, etc.
wendyluvscatz
wendyluvscatz
Senior Forum Member
Senior Forum Member (12.2K reputation)Senior Forum Member (12.2K reputation)Senior Forum Member (12.2K reputation)Senior Forum Member (12.2K reputation)Senior Forum Member (12.2K reputation)Senior Forum Member (12.2K reputation)Senior Forum Member (12.2K reputation)Senior Forum Member (12.2K reputation)Senior Forum Member (12.2K reputation)
Posts: 2.5K, Visits: 19.4K
After getting essentials I was thrilled by the substance options, you can randomly tile 3 textures as decals on top of the fabric layers on clothes so varying scales using images with alpha is quite doable, I ceated all sorts of new frabrics, it bakes them as a map.
wendyluvscatz
wendyluvscatz
Senior Forum Member
grouchmaxweb
grouchmaxweb
Thanks for all your suggestions I really appreciate it. I have now been able to create the look I was looking for. I do now have an issue with the  project crashing . I have created my actor and have saved as a custom actor, I have used this Actor 3 times,Is this a known issue. I am using  Win 10 IClone 6 pro. Is there some way I can find a log of what is causing the crash. Message just says Windows is looking for solution and will advise if they find one. So frustrating with no error log or code
grouchmaxweb
grouchmaxweb
I have found the error log. Does this mean anything to anybody? Or is it a program reload required?
Faulting application name: iClone.exe, version: 6.4.2527.1, time stamp: 0x56a7ad07
Faulting module name: ntdll.dll, version: 10.0.10586.103, time stamp: 0x56a8483f
Exception code: 0xc0000374
Fault offset: 0x00000000000ee71c
Faulting process id: 0x1590
Faulting application start time: 0x01d16c321d94866b
Faulting application path: C:\Program Files\Reallusion\iClone 6\Bin64\iClone.exe
Faulting module path: C:\WINDOWS\SYSTEM32\ntdll.dll
Report Id: f9b66b93-e6fd-469c-ae72-e791b9007bf2
Faulting package full name:
Faulting package-relative application ID:
Cheers
Snarp Farkle
Snarp Farkle
Posts: 770, Visits: 3.6K
grouchmaxweb (2/21/2016)
Cheers
Hi grouchmaxweb,
You should send this to support, they did put out a temp patch update to try.  It's specifically for the 6.4 crash issues.
See here: https://forum.reallusion.com/270810/OFFICIAL-iClone-64-Issues-Thread?PageIndex=10
grouchmaxweb
grouchmaxweb
Thanks just FYI what they suggested didn't work for me. Will keep my eye on the updates on that link. Thanks Again
