Hi Everyone, 3DXchange 6.4 has been released today and with it comes a number of fixes and enhancements. However if you do still find any bugs, issues, glitches or other general annoyances, please can you post them here. As always, do feel free to post general feedback in your own threads, but it will help us greatly if we can keep all outstanding 3DXchange issues in one place. This will help the development team track and eradicate any nagging problems. Please do try to provide your full system specifications and a detailed description of the problem when posting. Many Thanks.
rampart
rampart
Last Active: 6 Years Ago
Posts: 1.4K,
Visits: 5.1K
I downloaded installed patch 6.4 for 3dxchange. Oops! When I load application and click update it says I have 6.4.1327 Installed, and the latest version is 6.4.2527 So where do you get this file or the message a mistake?
jamie3d
jamie3d
Last Active: 7 days ago
Visits: 192
Windows is telling me 3dexchange 6.4 instal has an invalid signature and could harm my pc?
rampart (2/2/2016) I downloaded installed patch 6.4 for 3dxchange. Oops! When I load application and click update it says I have 6.4.1327 Installed, and the latest version is 6.4.2527 So where do you get this file or the message a mistake?
There was an issue with build numbers but this has now been corrected. The latest build of 3DXchange 6 is 6.4.1327. Apologies for the confusion.
jamie3d (2/3/2016) Windows is telling me 3dexchange 6.4 instal has an invalid signature and could harm my pc? There is an issue with the signature in the updates but it won't harm your computer to install anyway. However you can update using LiveUpdate if you prefer. If you do use LiveUpdate, please update iClone 6 first, then perform the Character Creator and if applicable the 3DXchange 6 update. You can start LiveUpdate from Start > All Apps > Reallusion > LiveUpdate.
shavmark
shavmark
Last Active: 8 Years Ago
Visits: 29
this issue is still present in 6.4 https://forum.reallusion.com/241119/Export-to-FBX-resets-images-to-applocaltemp3dfxI tried http://usa.autodesk.com/adsk/servlet/pc/item?siteID=123112&id=22694909 and by doing an import/export and it seemed to help by moving the files out of the temp space as appropriate.
8 Years Ago by
shavmark
Last Active: 3 minutes ago
Posts: 15.7K,
Visits: 30.5K
I can confirm this. I exported an iAvatar to a specific directory and found only the FBX file. There should also be a <avatar-name>.FBM folder with the textures. The only way to have this folder created is by reimporting the exported character as this forces the creation of a .FBM folder. This used to work; I have an export from November 2015 that is correct. EDIT: To clarify: this is a problem, because as soon as you close 3DXchange your exported FBX file will have no textures.
8 Years Ago by
Wolfzone Digital
Wolfzone Digital
Posts: 1.1K,
Visits: 2.8K
I can also confirm this. When exporting to .fbx no texture file. Also the fbx does not keep the all the viseme and facial morphs of CC characters so facial animation breaks down.
WOLF'S TRADING POST IS OPEN COME IN FOR A VISIT
"May you one day see what my eyes have seen...and be better for it" - Wolf www.wolfzonedigital.com
3DUncovered
3DUncovered
Visits: 103
Exporting to fbx to use in unreal engine 4, something is happening with the root bone.. lost compatibility with previous exports because the root bone has now gone after export.. hips become root.. although it does look like these is remains root bone from ground as can see in screenshot. Whats changed, how can I get the root bone back how it was?
Posts: 15.7K,
Visits: 30.5K
@3DUncovered: Did you try to reimport an exported model from 3DXchange to see if the root disappears then as well? Obviously export to import breaks down somewhere; the question is where.
