DrawPlus X8 not working with CTA (Keyframe animation) WARNING
Posted By lesdodds 9 Years Ago
jann
jann
Posts: 146, Visits: 4.5K
jlittle (2/1/2016)
Yes, I have seen that anytime you use something like Shading, Pressure, Line Style, Brush, etc. the image is rendered as a bitmap.
I believe this has been true for all versions on DP.
It's unfortunately not only about special styles and shadings - but also standard line caps, which the software choose for you as standard.
When starting a new basic drawing, the line cap is "flat" by default.
When starting a keyframe drawing, the line cap is "rounded" by default. But sometimes while using just basic line drawing tools, the line cap automatically changes to "flat" without you noticing it. So - everytime you export a drawing/animation to flash (.swf) you need to check all the lines (also lines in shapes!) and make sure the caps are set to "rounded".
jlittle
jlittle
Posts: 1.9K, Visits: 17.3K
Jeff
jann
jann
There is a bug in DrawPlus X8 that results flash (.swf) vector graphic exporting as a bitmap, if you use lines in your drawing and the line cap is set to something else than "rounded".
Follow the thread in Serif forum:
jlittle
jlittle
I tried it with DPx5 (12.0.4.27) and it worked fine (no image) so I guess it is just DPx8 that has the issue.
Jeff
lesdodds
lesdodds
Distinguished Member (2.8K reputation)Distinguished Member (2.8K reputation)Distinguished Member (2.8K reputation)Distinguished Member (2.8K reputation)Distinguished Member (2.8K reputation)Distinguished Member (2.8K reputation)Distinguished Member (2.8K reputation)Distinguished Member (2.8K reputation)Distinguished Member (2.8K reputation)
Posts: 246, Visits: 2.6K
jlittle (1/12/2016)
Les,
I tried what you said and sure enough there is an image stuck in there.
Not sure why that is but I guess you can't convert from a drawing to a keyframe and expect it to work with CTA2.
Only with DP x6, x4,DPx5 (12.0.4.27)  & DPx8 (14.0.0.19)...It was the update to DPx8 (14.0.1.21) that corrupted the SWF file.
I typically:
1) create objects in a drawing doc and copy to a keyframe doc to do a swf export or
2) create the object in a keyframe doc.
Jeff
Myself also but for fast job or second thought drawings I convert.(or use to):P:P:P
Also thanks for Buddy hair and RS props... I love them.:cool:
Lester:)
 My YouTube
My Facebook
"All the adversity I've had in my life, all my troubles and obstacles, have strengthened me... You may not realize it when it happens, but a kick in the teeth may be the best thing in the world for you."
-Walt Disney
jlittle
jlittle
Les,
I typically:
Jeff
jlittle
jlittle
Les,
I usually COPY from a drawing to a keyframe for SWF export and never had any problems.
Never did a "conversion" though but I'll try that when I get home later tonight.
Jeff
lesdodds
lesdodds
jlittle (1/10/2016)
Ah yes, I see that.
I replicated your object with my DPx8 and had no problem, it showed up with 2 indexes.
That leads me to believe that it is probably in the file, not the shape or some other object (hidden?) is there.
I'm sure you have tried it again with a new file?
What version of DPx8 are you using? Mine is 14.0.1.21 (64bit).
Jeff
I have the same version of DPx8.
Try starting a standard vector file and then change it to Keyframe. I think the program adds something during conversion. Thanks for your help
Lester:)
 My YouTube
My Facebook
-Walt Disney
jlittle
jlittle
Ah yes, I see that.
I then decompiled both SWF files and found a difference, yours has an image in it whereas mine did not.
---------------------------Yours -------------------------------------- Mine
https://forum.reallusion.com/uploads/images/8b0765df-d952-421f-aff9-623b.png
I opened it with DPx8 but could not find any image on the page, layers or anywhere.
Did you perchance use a gradient or something that would force it to convert to an image?
I deleted your quick shape and made a new one and the same problem persisted.
Jeff
lesdodds
lesdodds
jlittle (1/9/2016)
Les,
What was the problem?
I opened the file in DPx8, exported to SWF, dragged and dropped it onto CTA 2 (Pipeline x64, V2.15.2328.1) and no problem.
The SWF was 1.22KB in size.
Jeff
Make it RS, only one index showing and if you set it to skin the color goes to dark gray.
https://community.serif.com/forum/69176/drawplus-x8-will-not-be-fixed-keyframe-animation
Lester:)
 My YouTube
My Facebook
-Walt Disney
