jarretttowe
jarretttowe
Posted 10 Years Ago
Visits: 3.0K
Hi. I am doing an animation and I am getting the dreaded texture crawlies. It's worse with substance materials than bitmaps, but bitmaps exhibit it a bit as well. Any help would be appreciated. I am thinking of trying it at 4k as a test.
Posted 10 Years Ago
I encountered that also, on a "substance" material I created.
I bumped up my anti-aliasing and that helped, but didn't completely cure it.
Can you try "Baking" your substance texture onto your object (so it's not using a "substance" any more) and see if that helps? I'd be very interested in the results.
jarretttowe
jarretttowe
Posted 10 Years Ago
Visits: 3.0K
Where do i find that control to bake it? I am looking, but have not figured out where it is!
Posted 10 Years Ago
LOL... it's one of those things I am aware of, but haven't used yet.
I think on the "Material" tab, I think there's a "Bake" button of some sort. I'll skim through the manual and see if I find anything quick...
ADDED...
Look a the "Edit --> Bake All Substance Textures" menu. See what that does.
Per the manual, it says, "This command bakes the substance texture to the eight channels of the prop."
(As I said, I've not used it yet. Maybe you can teach me.)
jarretttowe
jarretttowe
Posted 10 Years Ago
Visits: 3.0K
sweet. now if i can just get this scene to stop crashing (3 cc characters on a 16gb laptop with a 980m!) I will be in business!
Posted 10 Years Ago
Here is a little video I made that shows the flickering/shimmering problem I had. "Baking" the substances seems to help quite a bit.
This was all rendered at 1920x1080 resolution to an MP4 format. It is best viewed in full-screen, high-def mode.
