Hinge constraint reverse
Posted By ByBry 10 Years Ago
primaveranz
primaveranz
Posted 10 Years Ago
Last Active: 6 Months Ago
Posts: 203, Visits: 1.2K
I'm guessing the OP is still awaiting an easy to follow answer though  ;)
Posted 10 Years Ago
Posts: 8.2K, Visits: 62.6K
This one probably hinges (sorry :P ) around wether or not the door requires the turning of a door-knob. Nothing like a reach target with rotation and an animated doorknob!
mark
mark
Posted 10 Years Ago
Posts: 4.9K, Visits: 16.7K
My criteria is usually... will it look believable and how long will it take to accomplish :P
PROMO-BACK2
Delerna
Delerna
Posted 10 Years Ago
Distinguished Member (8.5K reputation)Distinguished Member (8.5K reputation)Distinguished Member (8.5K reputation)Distinguished Member (8.5K reputation)Distinguished Member (8.5K reputation)Distinguished Member (8.5K reputation)Distinguished Member (8.5K reputation)Distinguished Member (8.5K reputation)Distinguished Member (8.5K reputation)
Posts: 1.5K, Visits: 14.8K
You dont need to use physics to accomplish that and keyframing is certainly a legitimate way to do it. I usually do it by key framing as well but the question raised my interrest. I must say i quite liked how it works with physics though and it probably makes it simpler by not having to keyframe. I just animated the character and the door just responded to that animation. Havent done it often enough though to make my mind up whether i prefer it with physics or keyframing. I guess there could be usefullness both ways. It was fun doing it and increased my experience with physics. Thats something.
i7-3770 3.4GHz CPU 16 GB Ram
GeForce GTX1080 TI 11GB
Windows 10 Pro 64bit
mark
mark
Posted 10 Years Ago
...being a simple kinda guy I would just keyframe the door to do what is needed .  I guess I missed something but I'm not sure why you would need physics to do this..?
PROMO-BACK2
Posted 10 Years Ago
Posts: 15.8K, Visits: 31.4K
It's good to see people cooperating to find a solution WITHIN iClone...:P
Delerna
Delerna
Posted 10 Years Ago
Hi kellytoons
Yes i tried that but in my example the door doesnt stay closed that way
In my experience
Most doors (depending on how close they are to a second wall only open around 90 dtegrees before hitting that wall
If they are in the middle of a wall then opening 180 degrees would break the hinges
Also most doors only open on one direction from the wall. They have a frame they fit into stopping them from opening the other way
Thats why i chose -170 to 0 for my door
There are exceptions of course so yes. You need to choose whatever numbers fit your situation
Now i better get to work. Lol
Posted 10 Years Ago
Posts: 9.2K, Visits: 22.1K
Sorry, no knowing about the iClone physics, but I do know doors -- to open a door all the way (so as in Real Life) the angle of rotation needs to be 180 degrees, or thereabout.  And to rotate the other way, the same.  So using -160 to 0 is only half a rotation (my gut tells me you need to set it for -160 to +160 but I haven't played with this at all).
If I'm out of line just ignore me.
Delerna
Delerna
Posted 10 Years Ago
Hmmmm. That sounds interesting markab
The settngs i used were very simple and depends on which way the door opens
I used min -160 max 0 for the rotation limits
The force i set to 0.5 to close the door slowly
I also change the bounce amount and there is also a resistance setting in there somewhere
Im at work at the moment and cant remember everything exactly but i think the primary 2 are the 2 i mentioned first
markab
markab
Posted 10 Years Ago
Veteran Member (543 reputation)Veteran Member (543 reputation)Veteran Member (543 reputation)Veteran Member (543 reputation)Veteran Member (543 reputation)Veteran Member (543 reputation)Veteran Member (543 reputation)Veteran Member (543 reputation)Veteran Member (543 reputation)
Posts: 35, Visits: 1.7K
Hi Bybry,
Perhaps the easiest way is to simply change the physics setting of the door from Dynamic (assumed original setting) to Frozen when the door reaches the fully open position, then advance the time line ahead two seconds and then change the setting back to Dynamic.
Regards,
Mark
