pmaina
pmaina
Posted 11 Years Ago
Last Active: 7 Years Ago
Visits: 2.2K
animagic (11/20/2015) I would like to amend this a bit. 4GB in a video card is NOT a waste. This is for the NVidia GTX series, I don't know about AMD. I work with large projects and the VRAM does get used. I also disagree with the statement about the CPU. It does matter, as I found out from an earlier to a later generation i7. Anyway, given the budget of the OP, we're not looking to build a budget computer. Interesting... Would you mind sharing, please, some rough benchmarking data, say, between an i5 (or older Quad Core) v/s earlier i7 v/s Later i7? Secondly did you see any marked difference in performance between different spec Nvidia GTX graphics cards & can you quantify it somewhat? Thanks!
Posted 11 Years Ago
Last Active: 5 Months Ago
Posts: 15.8K,
Visits: 31.4K
rgreenidge
rgreenidge
Posted 11 Years Ago
Visits: 1.7K
I agree with Rampa. Also having all of that doesn't mean anything and it's a problem I ran into since iC3. This is a 64 bit program, but with limitations on how big your project file can be. I use lots of avatars, props, and backgrounds, and have run into problems where the project size was just too big and I had to split things up. I will come on here later to post how I found, and what I've found that caused problems including this week, and how I got around it. I haven't seen every demo and looked at very little postings of others, but most of them have been with 1-4 avatars in the same scene the most. Most of my scenes have no less than active 15 avatars in it. I went from a 2 GB to a 8 GB video card, and it improved nothing, and gave me the same exact problem. Plus unless I read it wrong, four GB of that video card memory is a waste (R9-290X), unless you are using two 4K monitors.
Home built; ASRock X570 Pro 4, AMD Ryzen 9-5950X CPU, AMD RADEON RX6900XT, 16GB video card, 131GB of RAM.
pmaina
pmaina
Posted 11 Years Ago
Visits: 2.2K
rampa (11/12/2015) Multi-card setups do not benefit iClone. Workstation cards do not benefit iClone. Really powerful CPU's do not benefit iClone. SSD's might help you load stuff faster, but will not really benefit iClone beyond that. They can be nice for faster disk though.
For a good iClone workstation, What you need is a decent CPU. That means an i5 or better. But you should choose a high end i7 if you can afford such.
For top performance, a really high-end Nvidia GTX gaming card. A 980 Ti or Titan X would be your best bet right now. Lots of VRAM is good.
Get as much system RAM as makes you comfortable. It's pretty cheap. ;)
iClone has a DirectX gaming engine, so double-precision workstation cards have no benefit. If your also doing CAD work, then consider it.
You can export some parts of your iClone projects as FBX to use in external rendering engines, but you cannot export everything. Trees cannot be exported. Soft-cloth physics cannot be exported. And probably a few other things as well.Best answer IMO. Why buy computing horsepower that iClone doesnt use? Wait for proper implementation of hardware accelerated rendering.
mark
Posts: 4.9K,
Visits: 16.7K
..yeah... if you can bump up that NVIDIA a bit it should be a super system!!! ;);)
fpacheco1960
fpacheco1960
Posted 11 Years Ago
Visits: 1.3K
I believe in getting the "Most Bang for the Buck". So when my home-built i5 desktop was showing it's age, I was considering upgrading to a current i7 system, when I came across a interesting deal I couldn't pass up. A 2008 Mac Pro Tower with (2) 4 core 2.8 GHz Quad-Core Intel Xeon CPU's for $160.00. I upgraded it with 26 gigs of Ram, 500 GB stripped SSD RAID, 4 TB Data drive, a Nvidia GTX 680 GPU flashed with a Mac boot ROM. OS X Yosemite on the Striped RAID, Windows 7 on a single Toshiba 256 GB SSD. I spent around $800.00 total and I am very happy with the performance. It rivals most i7 based systems. Upgrades I am considering are a High End Nvidia GPU, and larger SSDs. I found some software for creating a render farm using Mac Pro Towers, and the local vendor has 15 more Macs available, I might offer him $1500.00 for the lot. These Mac Pro Towers are tanks, made from thick aluminium and weigh 57 lbs empty! and the fans very rarely ever spin up to max. I think I got a pretty good deal, and the price to performance can't be beat. IMHO...
MacPro 4.1 (EFI Flashed to 5.1) * 48 GB DDR3 RAM * macOS Sierra 10.2 NVIDIA GTX 680 Mac Edition * Areca 1880-8 RAID Controller (Sata 3) (1) 480G Ultra II SSD * (macOS Sierra) * (1) 480G Ultra II SSD (Windows 10 Creators Update) Seagate 4 TB HD
TonyTiger
TonyTiger
Posted 11 Years Ago
Visits: 352
TonyTiger
TonyTiger
Posted 11 Years Ago
Visits: 352
Plus the 1.5 kilowatt power supply doesn't hurt either
TonyTiger
TonyTiger
Posted 11 Years Ago
Visits: 352
If you have the money,go for the Alienware Area 51 R2,I love mine,thing is built like a tank.You can customize it how ever you like and get a totally badass machine for around 3-4 grand.I got the I-7 5960 8 core with triple GTX 980S and 32 gigs of DDR 4 and absolutely love it.I could of saved a little money building myself but after pricing it out,I was only gonna save about 500 so I decided to go with Alienware and I absolutely love it-Runs Iclone with everything maxed out and doesn't break a sweat.Plus if something does go bad I have Dell to fall back on.Just my 2 cents
Alasandro
Alasandro
Posted 11 Years Ago
Visits: 1.5K
Thank you all. I am learning quite a bit here combined with research I'm doing on my own. I will be sure to post my final setup before purchase. It will be interesting to read the conversation regarding the pros and cons. Maybe even influence some modification.
