Eric (RL)
Eric (RL)
Posted 11 Years Ago
Last Active: 10 Years Ago
Visits: 1.0K
Are you the owner of a Noitom Perception Neuron with a full body package of 31 / 23 / 17 neuron sensors? If so, then you qualify for the iClone Perception Neuron Beta program where you can test out what your Neuron Suit is capable of with iClone 6's real-time 3D animation capabilities!
______________________________________
Eric (RL) Forum Moderator
Reallusion, Inc. https://forum.reallusion.com
"Simplicity is the ultimate sophistication." - Leonardo da Vinci
mtakerkart
mtakerkart
Posted 11 Years Ago
Posts: 3.2K,
Visits: 29.2K
Ouch! I've just receive my 11 neurons today. Will have I some trouble? I will use it only thursday because of my job.
Eric (RL)
Eric (RL)
Posted 11 Years Ago
Visits: 1.0K
Hi Mtakerkart!
Yes, technically it is possible to use the 11 Neuron set-up with iClone and Neuron Mocap Plug-in. However, the mocap accuracy and experience will not be as good as the minimum recommended Neuron amount. Please feel free to test it out and tell us what you think!
Posted 11 Years Ago
Visits: 22.1K
Eric, Just curious, but I don't even SEE a 31/17 Neuron suit on Neuron's site -- I see an 18 and a 32, but not those particular ones. Is there a disconnect here? Perhaps a terminology snafu? IOW, is the support you offer for those suits but you just call them something slightly different than Neuron does?
mtakerkart
mtakerkart
Posted 11 Years Ago
Posts: 3.2K,
Visits: 29.2K
Thank you Eric. I started to figure out my 11 neuron kit. For know , it's a nightmare. Not with your plugin wich works perfectly :-). I'm trying to figure out with Neuron support why some Neurons send wrong data and some are good. May be some were with magnetic field issue....
CaseClosed
CaseClosed
Posted 11 Years Ago
Visits: 781
I bought a 32 set, but I haven't received it yet. If they are arriving, fantastic!! So excited!!
Can I sign up now, even if I don't have the neurons in hand yet?
johnb4467
johnb4467
Posted 11 Years Ago
Visits: 668
CaseClosed, I imagine you can if you follow the link in the OP's post?
CaseClosed
CaseClosed
Posted 11 Years Ago
Visits: 781
johnb4467 (11/5/2015)
CaseClosed, I imagine you can if you follow the link in the OP's post? Thank you for the interjection my friend. Haha. Downloaded the beta and signed up. I hope to get the Perception Neuron kit soon.
Eric (RL)
Eric (RL)
Posted 11 Years Ago
Visits: 1.0K
Hi Kellytoon,
Apologies, my initial post was a bit misleading. The 17, 23 and 31 are the three of the minimum recommended configurations that allow a user to take advantage of full body motion capture (31 with full fingers motion capture). The 18 sensor kit and the 32 sensor kit are the two packages on sale on Perception Neuron, but you don't necessary have to use all the neurons you bought. It is important to keep in mind that all suits are the same - they come with a head strap, a body strap, arm straps, leg straps and gloves. Hope this clears up the confusion.
mtakerkart
mtakerkart
Posted 11 Years Ago
Posts: 3.2K,
Visits: 29.2K
Hi Mtakerkart!
After fixing magnetize issues with Noitom , I confirm it can work with only 11 Neuros:
I pre-order 7 more Neurons to have accuracy motion. Now I'm testing the possibility to let the neurons outside of the box on the suit in a safety aera. I don't want to remove every day the Neurons , and when you make a calibration with a Neuron configuration , it keeps the setting ....
