The entire Mixamo asset collection is free!
Posted By Rampa 10 Years Ago
Posted 10 Years Ago
Posts: 8.2K, Visits: 62.5K
Everything at Mixamo is free for an unknown amount of time!
That means characters and animations. I just downloaded a few. They convert super easy as Maya/HumanIK. I downloaded FBX, and it duplicated my actor bazillion times, so I would recommend BVH. wink emoticon
Apparently there will be a new Fuse in the next couple weeks too.
Threaded View
Threaded View
Forum Post The entire Mixamo asset collection is free! By Rampa ( 10 Years Ago )
Forum Post I thought Mixamo had gotten bought by Adobe and was temporarily closed... By Kelleytoons ( 10 Years Ago )
Forum Post Ah, yes indeed, they are starting to show their Adobe connections. If... By Kelleytoons ( 10 Years Ago )
Forum Post They convert super easy as Maya/HumanIK. I downloaded FBX, and it... By Kelleytoons ( 10 Years Ago )
Forum Post I just did default FBX for almost the whole library...then read this,... By 3doutlaw ( 10 Years Ago )
Forum Post I actually used FBX the first time, and it worked great. Then I... By Rampa ( 10 Years Ago )
Forum Post Yea, I just tried a sample export into iClone using those same steps... By 3doutlaw ( 10 Years Ago )
Forum Post I was able to download them in BVH for Max, load them into Max, and... By Kelleytoons ( 10 Years Ago )
Forum Post they have a few unique gems.. For the most part though, most of the... By planetstardragon ( 10 Years Ago )
Forum Post I discovered you can make your own "pack" of motions at Mixamo. When... By Rampa ( 10 Years Ago )
Forum Post [quote][b]rampa (10/6/2015)[/b][hr]I discovered you can make your own... By 3doutlaw ( 10 Years Ago )
Forum Post It's a bit of a trick. What you want to do is to start with a Pack --... By Kelleytoons ( 10 Years Ago )
Forum Post Hmmm, what's weird is that now I tried it without a pack and it works... By Kelleytoons ( 10 Years Ago )
Forum Post Ah, I think I see -- I think the "add to pack" is the approach you... By Kelleytoons ( 10 Years Ago )
Forum Post Well, I'm on page 16... LOL. I've also found a pretty reliable... By Kelleytoons ( 10 Years Ago )
Forum Post ...on to page 5 of 26. Sigh... Keep telling myself, this is free, so... By 3doutlaw ( 10 Years Ago )
Forum Post Page 14, woohoo! Past the half-way mark! :) By 3doutlaw ( 10 Years Ago )
Forum Post Ah, I went to page 30, and then started again from the back (page 52)... By Kelleytoons ( 10 Years Ago )
Forum Post 52? Oh, I am doing 96 per page, and ignoring some, so basically 75... By 3doutlaw ( 10 Years Ago )
Forum Post I had the best luck building a "pack" as has been discovered. For... By Rampa ( 10 Years Ago )
Forum Post My tip contribution - sort the motions out by "Most Recent" - it... By planetstardragon ( 10 Years Ago )
Forum Post [quote][b]planetstardragon (10/6/2015)[/b][hr]My tip contribution -... By 3doutlaw ( 10 Years Ago )
Forum Post [quote][b]3doutlaw (10/6/2015)[/b][hr][quote][b]planetstardragon... By 3doutlaw ( 10 Years Ago )
Forum Post And because I've now finished and saved all my custom packs in assets... By Kelleytoons ( 10 Years Ago )
Forum Post Rampa, maybe you should edit the first post with the "Lessons Learned"... By 3doutlaw ( 10 Years Ago )
Forum Post I did one small "pack" as explained and imported into 3DXchange 6 and... By animagic ( 10 Years Ago )
Forum Post you know, the last time Adobe gave something out like this for free,... By planetstardragon ( 10 Years Ago )
Forum Post [quote][b]planetstardragon (10/7/2015)[/b][hr]. - Looks like Adobe... By urbanlamb ( 10 Years Ago )
Forum Post I certainly understand that feeling -- it was exaclty mine (for... By Kelleytoons ( 10 Years Ago )
Forum Post [quote][b]mike_20091214085613313 (10/7/2015)[/b][hr]I certainly... By urbanlamb ( 10 Years Ago )
Forum Post Good for you. I suspect if I were younger I'd feel much the same way... By Kelleytoons ( 10 Years Ago )
Forum Post Only problem with the Mixamo stock characters is that when imported,... By GrannyJ ( 10 Years Ago )
Forum Post From this forum post, it looks like the next version of Fuse will also... By Rampa ( 10 Years Ago )
Forum Post Yipes -- the Auto-Rigger is REALLY good. I found a free character as... By Kelleytoons ( 10 Years Ago )
Forum Post [quote]So creating the morphs in Max ain't the issue, it's trying to... By vidi ( 10 Years Ago )
Forum Post Might be best to just grab the 12 packs off the "featured" page.... By Rampa ( 10 Years Ago )
Forum Post [quote]so I suspect you're right about using bones for the... By vidi ( 10 Years Ago )
Forum Post bones allow you to do detail work on the fly for more versatility.... By planetstardragon ( 10 Years Ago )
Forum Post Wow can't believe the resident dragon is making so much sense! ;)... By Bellatrix ( 10 Years Ago )
Forum Post I haven't tried it with a CC character, but I've done it with iclone... By planetstardragon ( 10 Years Ago )
Forum Post [quote][b]planetstardragon (10/8/2015)[/b][hr]I haven't tried it with... By Bellatrix ( 10 Years Ago )
Forum Post So is the best way to put these into iClone to use 3dXChange and put... By 3doutlaw ( 10 Years Ago )
Forum Post I'm sure the experts here will sort you out, but one thing I know is... By Kelleytoons ( 10 Years Ago )
Forum Post [quote][b]3doutlaw (10/9/2015)[/b][hr]So is the best way to put these... By Rampa ( 10 Years Ago )
Forum Post And thanks guys for the heads up on this Mixamo freebie thing.... By Bellatrix ( 10 Years Ago )
Forum Post I can also not understand why we have morph slider in 3D xchange for... By vidi ( 10 Years Ago )
Forum Post yeah, i had my heart set on the morphing animation, ....i was hoping... By planetstardragon ( 10 Years Ago )
Forum Post I truly appreciate ALL the discussion here, even though a lot (most?)... By Kelleytoons ( 10 Years Ago )
Forum Post [quote] since you *can* apply a morph via the facial animation... By mtakerkart ( 10 Years Ago )
Forum Post [quote]why not just do an entire body morph that way? [/quote] it is... By vidi ( 10 Years Ago )
Forum Post Back to Mixamo free stuff.... RAMPA... THANKS A... By RobertoColombo ( 10 Years Ago )
Forum Post yep, i agree....back on topic, i found that much of the mixamo... By planetstardragon ( 10 Years Ago )
Forum Post Just a suposition... Imagine that Adobe give all the mixamo mocap free... By mtakerkart ( 10 Years Ago )
Forum Post [quote][b]mtakerkart (10/8/2015)[/b][hr]Just a suposition... Imagine... By Rampa ( 10 Years Ago )
Forum Post Another way that I decided to sort my catagories, especially since I... By Rampa ( 10 Years Ago )
Forum Post Where are these anims? I went to the Mixamo site and clicking on anims... By Dr. Nemesis ( 10 Years Ago )
Forum Post [quote][b]Dr. Nemesis (10/9/2015)[/b][hr]Where are these anims? I went... By Rampa ( 10 Years Ago )
Forum Post since mixamo is now a part of adobe, you have to log in through the... By planetstardragon ( 10 Years Ago )
Forum Post It's very cool that these are all named pretty well. Remember we can... By Rampa ( 10 Years Ago )
Forum Post Thanks guys. These are very helpful. Import to Iclone is smooth as... By Dr. Nemesis ( 10 Years Ago )
Forum Post Great, thanks for tips all! By 3doutlaw ( 10 Years Ago )
