Photo Animating a Two Headed Turtle
Posted By ZackandMack 11 Years Ago
ZackandMack
ZackandMack
Posted 11 Years Ago
Senior Member (391 reputation)Senior Member (391 reputation)Senior Member (391 reputation)Senior Member (391 reputation)Senior Member (391 reputation)Senior Member (391 reputation)Senior Member (391 reputation)Senior Member (391 reputation)Senior Member (391 reputation)
Last Active: 10 Years Ago
Posts: 21, Visits: 49
I hope I am posting here in the correct forum.  I am searching for the proper Real Illusion product that will animate a talking photo of my two-headed turtle.  Will Crazy Talk 7 do the trick, or will I have to use another product, and if so, which product will suffice.  Thanks
AverageJoe
AverageJoe
Posted 11 Years Ago
Distinguished Member (11.4K reputation)Distinguished Member (11.4K reputation)Distinguished Member (11.4K reputation)Distinguished Member (11.4K reputation)Distinguished Member (11.4K reputation)Distinguished Member (11.4K reputation)Distinguished Member (11.4K reputation)Distinguished Member (11.4K reputation)Distinguished Member (11.4K reputation)
Posts: 2.4K, Visits: 10.1K
Yes and no.  Yes, CrazyTalk is the application to use to transform a photograph into a talking character.  However, with that said there are quite a few caveats.  One of which is the position or pose the turtle (aka character) is in. Typically the character should be fully facing the camera.  This is not a hard & fast rule, it really depends on the photograph in question. And secondly, CrazyTalk 7 can only do a single head or character at a time.  With some creative editing in post production you could make it work, but it will require significant effort on your part in a video editor or compositor to get both of the heads talking.
What I would do is make 2 separate projects, one for each head. Have your audio recording with both side of the conversation between the heads, and in CT animating the appropriate head during the appropriate pieces of the conversation, making use of both the Talking feature, as well as the Listen feature. Then do the 2nd head, reversing the times talking & listening for the second head.
Take both clips into an editor and with some good masking and audio syncing you should be able to make it look like the two heads are talking to each other.  Simple enough to describe, not so simple to actually do without some real effort though.
ZackandMack
ZackandMack
Posted 11 Years Ago
Thanks for your input and I totally understand your instructions regarding two separate projects.  The next question I would have if you could answer would be concerning the product Crazy Animation/er 2 Standard edition.  I believe this product can do two heads at once.  Will it do entire photos?  or are characters required?  The other question is more specific with any of the two products, Crazy Talk 7 and CTA2 Standard...it pertains to eyes.  Turtles have eyes on the sides of their heads.  Mammals have them in the front of their head.  Could eye movement be attempted with much work, or not?
Thanks in advance for your assistance in helping me decide which of the two products to purchase
AverageJoe
AverageJoe
Posted 11 Years Ago
CrazyTalk Animator 2 is specifically design for doing full figure 2D animation and is much more work getting something working.  In regards to your 2 headed turtle picture, no you would not be able to animate both heads in CTA, you'd have to create two separate characters.  The other issue is CTA expects that you'd be removing the head or face from said photograph to place onto a full 2D bipedal character.  With some creative work arounds, you might get something to work, but it would most likely be a significant effort, with lots of tricks to get it to work.
As far as the eyes on the side of the head, it's not something I've tried, and not sure how well it'd work out.  If I had to wager a guess though, I'd say no.
ZackandMack
ZackandMack
Posted 11 Years Ago
Understand completely.  So it looks like I should experiment with CrazyTalk 7 Pro and go from there.   Sounds cool.  Thanks again for the input.
ZackandMack
AverageJoe
AverageJoe
Posted 11 Years Ago
Can you share the photo in question?  Maybe it'd spark a creative solution...
jlittle
jlittle
Posted 11 Years Ago
Posts: 1.9K, Visits: 17.3K
Yes, you would have to create two heads and attach each of them to a character but you can make all but the head invisible so that you have just the "floating" heads which you can then place over the original photo. Depending upon how much head movement you want some touchup to the underlying photo might be required.
You could even remove the neck and make it a prop which you could then move as needed.
A lot depends upon the angle of the picture of course.
I've taken a photo and animated three heads in it that way without any issues.
Jeff
ZackandMack
ZackandMack
Posted 11 Years Ago
Already purchased CrazyTalk standard with the basic suite to test things out.  Thanks for all the input.  Maybe I might switch to CTA2 Standard and work with that also.
As for a photo.  Was unable to post one here, but head to FB and see ZacknMack, or Zack and Mack.
ZackandMack
ZackandMack
ZackandMack
Posted 11 Years Ago
We wanted to thank all you humans for your help in getting us vocalized.  We wanted to post our first effort using Crazy Talk 7 Standard.  Our human doesn't let us out of the tank very often, so we did what we could.  Hope it satisfies.  And yes, we are a real, two-headed turtle.
AverageJoe
AverageJoe
Posted 11 Years Ago
Nice job... If I may offer a suggestion though... The jump from the natural eyes to the animated eyes is a bit garish...  Instead of leaving the listening head with it's natural eyes, you could animate him in listening mode, so the eyes remain the same regardless if the head is talking or not.  Also, when the first head is done talking, instead of going back to the natural eyes, leave them on the animated ones.  Then it's not so drastic of a change for them during the clip.  Just a suggestion though.  Either way, great job.
