Help with process please.
Posted By Brennon 10 Years Ago
Brennon
Brennon
Posted 10 Years Ago
Veteran Member (763 reputation)Veteran Member (763 reputation)Veteran Member (763 reputation)Veteran Member (763 reputation)Veteran Member (763 reputation)Veteran Member (763 reputation)Veteran Member (763 reputation)Veteran Member (763 reputation)Veteran Member (763 reputation)
Last Active: 9 Years Ago
Posts: 17, Visits: 22
Hi all,
As it says, I am a newbie in here. Thanks for be patient with me.
I would like some opinion of what you would consider the best approach to what I need to achieve.
I have a WPF application which will host a Unity surface.
In this WPF application, we are generating our own TTS output, which supports viseme etc.
I need to create a custom head model in 3D. This model is of a female, has no hair and no body.
My understanding of the process is a bit broken:
1) I would use iClone 6 PRO with CC to create the head
2) I can generate a script of the lip sync using our audio files? Is that script "playable" inside of Unity?
3) I can export that with the Unity plugin
Can I programmatically run/call the scripts previously created in iClone/CC, inside my Unity player?
Is this the best way to get the lip sync scenario to work or is there a way (or plugin or script) which would allow me to just export the head, and run lip sync in realtime from my own audio?
I appreciate any and all help with this.
Cheers
