Eyebrows, how to modify??
Posted By theschemer 11 Years Ago
theschemer
theschemer
Posted 11 Years Ago
Distinguished Member (7.6K reputation)Distinguished Member (7.6K reputation)Distinguished Member (7.6K reputation)Distinguished Member (7.6K reputation)Distinguished Member (7.6K reputation)Distinguished Member (7.6K reputation)Distinguished Member (7.6K reputation)Distinguished Member (7.6K reputation)Distinguished Member (7.6K reputation)
Posts: 1.4K, Visits: 2.9K
I guess I forgot to unzip the Essential Learning resource. Where is the proper place to put all the resource maps that come with it? I could not find the instructions for that part and I am sure there is a proper recommended place. :blink:
Thanks,
TS
p.s. Never mind....I found the empty folders and copied the files over. :)
Galfridus
Galfridus
Posted 11 Years Ago
Posts: 727, Visits: 2.2K
After further reading of theCharacter_Creator-Character_Skin_Design_Guide.pdf...It  confirms that:-
“Translate, Rotate and Scale the eyebrow: Special adjustments for Eyebrows only. Note:Only works for embedded content”.
Geoff.:(
https://forum.reallusion.com/uploads/images/ba17ca1f-2bbe-4b61-819c-6bdf.png
Galfridus
Galfridus
Posted 11 Years Ago
Transform tools“eyebrows” works for default selection from Type drop downselection menu.
I find when I choose “custom” and load an eyebrow from the CC Essential morphs and skin - Custom Eyebrows texture folder, the transform then have no effect.
The custom eyebrows in the CC Essentials pack would seem to have only a fixed position and are therefore somewhat limited.
Bug or user error?
Geoff.
Posted 11 Years Ago
Posts: 8.2K, Visits: 62.6K
The rotation is also very helpful. :)
JimmyB7
JimmyB7
Posted 11 Years Ago
Posts: 198, Visits: 3.2K
https://forum.reallusion.com/uploads/images/88135c3a-8430-401c-b92e-7f13.jpg
CyberpowerPC, 64 GB Ram, 64bit Windows 10 Pro, Intel Core i9-10980XE 18 Core CPU,  ASUS TUF X299 Mark 1 Motherboard, ROG-STRIX-RTX2080TI-O11G-GAMING graphics card, Toshiba 3TB hard drive, 3 x Seagate 3TB hard drives, RAGNAROK 801 Full Tower, LEPA G1600 1600W power supply, Killer WI-FI 6,  ASUS PA329Q 32" 4K/UHD IPS Monitor.
Posted 11 Years Ago
Posts: 8.2K, Visits: 26.5K
Thanks Rampa.
When I moved them before, I used the "move/stretch/morph" tool, or whatever it's called.  The one where you get the yellow highlight on the body part you're adjusting.  Using that to move the eyebrows up just sort of "blurred" them up higher.  I overlooked this one.
I was so close.
I still think the base character ought to be adjusted.  I'll modify my post in the "Improve Character Creator" section.  Thanks again.
Posted 11 Years Ago
justaviking (9/13/2015)
On a related note...
How do we move the eyebrows themselves up onto the "bone" area of the eye socket, instead of being on the upper eyelid?
Please forgive my lack of artistic talent, but hopefully these pictures will illustrate what I mean...
https://forum.reallusion.com/uploads/images/e55b7f3a-be37-4b15-b2e4-774b.jpg
https://forum.reallusion.com/uploads/images/a02be722-535e-4ff9-8a6d-50ff.jpg
https://forum.reallusion.com/uploads/images/e7add634-3db1-4c63-a5a9-fd21.jpg
I don't think I'm imagining this.
I even did a Google images search for "
male eyebrows."  :w00t:
They do tend to be a bit low. You can translate them at the bottom of the "eyebrow" section of the "hair" tab of the "skin_head".
Posted 11 Years Ago
theschemer
theschemer
Posted 11 Years Ago
Thanks for the info. I actually was at the point but it seemed the warning of "flattening" the image scared me away. I went ahead and tried it, and it definitely changes the quality of the image, but I was able to mod the eyebrows good enough. I would have liked to be able to straighten them (eyebrows) out a bit more. Once the image was done and I exited the appearance editor it looks acceptable and better than I thought is was going to.
TS
JimmyB7
JimmyB7
Posted 11 Years Ago
Appearance (Button), Activate Appearance Editor, Actor, Skin_Head, Hair, Eyebrows.
