Sometimes you'l get what I refer to as a false error saying "Not Responding".. when you try to load the project.
Open an empty project 1st. Set the parameters to "Quick Mode" or even Wire Frame.
Now when you load the Project it should open in that state..requiring a lower demand on the graphics card.
It could also be your graphics drivers need updating before you attempt the opening.
Press the following keys in Windows (regardless of the version)
CTRL+Shift then ESC simultaneously or simply put, while holding those two keys down..
Those keys should open your "Task Manager" where you want to view the "Processes" Tab. You can do this before or after opening the project, your choice.
In that Processes Tab you will see a listing of all the processes running and the CPU activity of each in the right hand column.
Find iClone, and watch for the CPU numbers to change.
If the numbers are changing at all, then iClone has not actually stopped responding, it is just gathering up storage space to place the temporary files.. It may take longer than you want for it to finish, but leave it alone unless the CPU indicator goes completely flat and stays there. You would be surprised how many times you can have a "Not Responding" error showing when it is just a system delay,
Last but not least, make sure sure have enough hard drive space to open up the project twice...because it requires that much space initially to write the "Auto Backup files in case it actually locks up.
That's as simple as I can explain it.
Good Luck.
SKYPE ID: rc.650
