Modifying G6 Clothing
Posted By Lord Ashes 10 Years Ago
Lord Ashes
Lord Ashes
Posted 10 Years Ago
Posts: 1.3K, Visits: 1.6K
How to modify G6 Clothing? Let me count the ways...
Texture/Opacity Replacement:
The easiest way to modify clothing if the clothing is somewhat like existing clothing is to create an new texture map and/or opacity map. For example, Heidi's existing dress can be shortened by applying an opacity map which trims off the bottom of the dress. In some cases a corresponding change needs to be made in the Skin opacity map to avoid nasty holes in the body. With clever use of opacity an existing clothing item can be changed significantly using this method. It should be noted that opacity does not change how the mesh reacts to softcloth/physics. For example, if you use opacity to make the bottom of the dress fringe, the fringe will look like fringe but it will act like solid softcloth.
Mesh Replacement:
The clothing mesh in G6 characters is one of the few meshes that can still use the Replace Mesh option in 3DXchange. This allows the clothing mesh to be significantly changed but the number of vertices must remain the same (otherwise the new mesh will be rejected). With this option larger changes can be made but it is a great pain if the source (e.g. Heidi's dress) is going to become something significantly different (due to the vertices requirement).
New G6 Base:
As far as I can see the last resource is to export the G6 character, edit externally as desired, and then re-import the character. This involves re-boning the new characters (if you exported as OBJ). This solution should provide the maximum flexibility but if you only have the PRO version of 3DXChange (so you can not export FBX), the re-boning process may be difficult. I am still looking for someone who has experience with this to provide some fairly easy instructions.
EDIT:
If content designers start to implement clothing using the last option, will this result in a tonne of G6 Bases (similar to the G5 Cloth bases)? Will this also mean that you will not be able to easily mix and match tops and bottoms (like you could do with G5 characters because they had a Upper and Lower component) because both the top and bottom will be part of a single base? In my opinion this is one of the biggest disadvantages of iClone over DAZ Studio. In DAZ Studio the clothing is all implemented independently (not part of the character mesh) so you can mix and match, add and subtract with no issues. The DAZ Studio conforming clothing (which automatically adjusts when characters proportions are changed) is also an excellent feature. We will see how the new Character Creator will handle that in iClone.
EDIT2:
It seems that this post answers some of these questions. I have not tried it yet since I am at work but it seems that the Character Creator comes with a bunch of standard bases available for Content Developers to use as the base for their own creations.
Threaded View
Threaded View
Forum Post Modifying G6 Clothing By Lord Ashes ( 10 Years Ago )
Forum Post [quote] Mesh Replacement: [/quote] Doesn't work at all. The CC... By mtakerkart ( 10 Years Ago )
Forum Post [quote][b]mtakerkart (9/4/2015)[/b][hr] [quote] Mesh Replacement:... By Lord Ashes ( 10 Years Ago )
Forum Post Hi, Strange because it's work fine for me . Zbrush or 3dsmax. By Sen ( 10 Years Ago )
Forum Post @Sen I used 3Dcoat. May I missed something... I just exported in obj... By mtakerkart ( 10 Years Ago )
Forum Post Actually you can't modifier cloth , because it's base on body morph .... By Sen ( 10 Years Ago )
Forum Post Thank you very much Sen. I will post your answer in other thread . By mtakerkart ( 10 Years Ago )
Forum Post [quote][b]Sen (9/4/2015)[/b][hr]Actually you can't modifier cloth ,... By Lord Ashes ( 10 Years Ago )
Forum Post EDIT: Removed By Lord Ashes ( 10 Years Ago )
Forum Post A few things I've established with 2 rounds of tests using CC... By Bellatrix ( 10 Years Ago )
Forum Post [quote][b]Bellatrix (9/11/2015)[/b][hr]A few things I've established... By Lord Ashes ( 10 Years Ago )
Forum Post [quote][b]Lord Ashes (9/11/2015)[/b][hr] [quote][b]Bellatrix... By Bellatrix ( 10 Years Ago )
Forum Post They're using some interesting method that "rigs" the cloth to the... By Rampa ( 10 Years Ago )
Forum Post The body, not the clothes. The clothing follows the body, so if you... By Rampa ( 10 Years Ago )
Forum Post There are indeed quite a few ways to rig clothes to characters... In... By Bellatrix ( 10 Years Ago )
Forum Post Hello, How work a CC avatar. Basicaly, it's a rig mesh with custom... By Sen ( 10 Years Ago )
Forum Post I understand that in CC the clothing is conforming so if you make an... By Lord Ashes ( 10 Years Ago )
Forum Post I think it'll all "click" for you as to why pretty soon. Your getting... By Rampa ( 10 Years Ago )
