Just a heads up to the community.
My new installation of 3DXchange Pro Pipeline V6.11 was crashing about 1/2 through the conversion process. After extensive troubleshooting of background programs and services I discovered that EVGA Precision 16 was the culprit causing 3DXchange 6 to crash. For every 10 attempts I was only getting one character imported into iClone 6. Frustrating to say the least. Shutting off Precision ended my problem.
I tried MSI Afterburner as a substitute for Precision 16, It seems to play better with 3DXchange 6, so that may be an alternative to whoever has this same issue.
I see that 3DXchange is a 32 bit program. Is there any reason a 64 bit version has not been released? (just curious).
System Info:
