Fede P.
Fede P.
Posted 10 Years Ago
Last Active: 11 days ago
Visits: 326
Good morning everyoneI have two annoying problems with iClone 6.11.1809.1The first:I really can not do "drag and drop" images jpg or pngI tried both without ctrl key pressed that button with ctrl pressedThe only way is to copy the directory "2d Background" at this point I see the image and drag (but can find only jpg and not png images)The second:I still see as "not installed" all pack drm I purchased, I tried everything, reinstalled the program, deleted the contents of the directory "C: \ Users \ Public \ Documents \ Reallusion \ Template \ 6 iClone Template \ iClone Template \ Pack "but, upon reboot recur packsIf you install the program sees that are installed and if "continuous" causes me a copy of the contents of the package, I find myself with more than a duplicate item and, in any case, the display disappears and the pack is always referred to as "not installed"Help!!! Fede addition: I had the same problem with Windows 7 64-bit
My setup, PC windows 10 cpu Intel i7 950 3,07 GHz Ram 6 GB, HD 2X SSD Samsung 830 series 512 GB Video Graphics card Nvidia GTX660 2GB GD5
Posted 10 Years Ago
Try dragging with the right mouse button. That's "right-drag," as in, "not the left button."
Fede P.
Fede P.
Posted 10 Years Ago
Visits: 326
justaviking (8/19/2015) Try dragging with the right mouse button. That's "right-drag," as in, "not the left button."I tried but not working I can drag and drop from the content manager to a file directory (or desktop) but not vice versa additionI had the same problem with Windows 7 64-bit
Fede P.
Fede P.
Posted 10 Years Ago
Visits: 326
Good morning, I have solved the first question in this operation mode (sorry for my english) I find a file "iClone.exe" --> right button clik to "property" Tab Compatibility I ran the "instrument for resolving compatibility issues" Now is working perfectly For the second questions I hope for a solution with a new upgrade Thank you Federico
