mwgis48
mwgis48
Posted 17 Years Ago
Visits: 96
CAN THE ACTORS CHANGE CLOTHES DURING A SCENE?
aknzrdude
aknzrdude
Posted 17 Years Ago
Last Active: 6 Years Ago
Posts: 2.1K,
Visits: 11.0K
not sure how to answer the question 1) are there motions where characters change clothes - haven't seen them 2) can you change the texture of the characters or change thier clothes BEFORE you render- yes you would have to render the original scene, then apply new textures/clothes, then render again with the new clothes - maybe you might need to create a separate project where they are in a room to imply changing clothes. Which leads to item #3 below - 3) do you need to render one continuous take? - then you cannot do it unless you have setup a complex scene where you have the characters in new clothes hidden somewhere, and make them visible as you make the original character invisible. unless you absolutely have to do the one continous take, you would probably have to create separate projects - most folks render bits and pieces and assemble them later
sumthinwong
sumthinwong
Posted 17 Years Ago
Last Active: 8 Years Ago
Visits: 8.2K
Not sure if this will work for you but you might give it a try. Just create another character with the same performs and motions with different clothes, then put them both in the scene. Make one invisible until you need the clothes changed then turn the active character off and the other on. Here's an example
All arts is political, otherwise it would just be decoration. And all artists have something to say, otherwise they'd make shoes.
Earl of Oxford
mwgis48
mwgis48
Posted 17 Years Ago
Visits: 96
Thank you all the help, what I mean is I start with Jane, and she then wants to go out but want a new top how do I change the top or paints so she can go with trey for the night?
Cricky
Cricky
Posted 17 Years Ago
Posts: 2.8K,
Visits: 13.8K
Alley
Alley
Posted 17 Years Ago
Posts: 3.7K,
Visits: 12.8K
Cricky's method is sort of demonstrated on the homepage of my website, link below in banner. It's just the animation playing on home page.
Alley
Cricky
Cricky
Posted 17 Years Ago
Posts: 2.8K,
Visits: 13.8K
Darren01
Darren01
Posted 17 Years Ago
Last Active: 4 days ago
Visits: 4.1K
it would be a good feature for a future release, although I figure it would be a very difficult task as the clothing item would need to become a seperate 3D object. I wanted a scene where a guy walks into a room, takes off his jacket. But you can't do it realistically. Even with the method described above, there will be no actual action/transition showing the guy removing his jacket. The jacket will just magically disappear
_________________________________________________________
elliespotter
elliespotter
Posted 17 Years Ago
Visits: 1.5K
I wanted to do a scene where my avatar kicked off her shoes and went so far as creating props and animating frame by frame and then thought "THIS IS MADNESS" and went back and looked at the script. A simple camera change and adjustment to dialogue created a much better scene within the limitations of the application. On the other hand, I have done an anime style transform http://www.youtube.com/watch?v=F97htyWm96s using the same avatar base and different outfits, using the same animation sequence and adjusting visibility during the scene. Now, I can imagine that, in a murder mystery perhaps, a character removing his coat and putting it on a peg could be a critical moment in the story - leaving a vital clue for the viewer maybe - but for the other 999 from a thousand scenes, I'd look at a script revision as clumsy animation loses viewers.
Kind regards, Alex
DesertWalker
DesertWalker
Posted 17 Years Ago
Last Active: 9 Years Ago
Visits: 508
It will be very difficult to do. Not only the jacket has to be a separate object. It must also flex and move neatly and in synch with the movement of arms/body during the taking-off process. After taken off the jacket needs to be folded and flex in a convincing manner. Even if this is feasible after 10 releases down the road, it won't be the strength of the app. It is better to modify the script.
