Creating a Perform menu for Props
Posted By TimV 11 Years Ago
TimV
TimV
Posted 11 Years Ago
Last Active: 7 Years Ago
Posts: 126, Visits: 426
Hi:
I have searched the forum for Perform and Perform Menu.  I have certainly seen animation clips for various actors that are linked to the Perform menu which is available by right clicking the actor / avatar.
What I have not found (including the manual) is a way to create / attach the framework to my aircraft (My ongoing V22 animation).  Now that I have the propellers rotating, I have many more parts to animate and it would be nice to be able to click select them from a menu, at least to get them operational and tested (what is a realistic time to lift the gear and close the doors - which I can get from actual video footage).  I would then like to be able to save various clips so that when I try to put a path and timeline in place, I could drop the clip on the timeline.
To animate a whole timeline, I can envision a takeoff where I would close the doors, start the props from stopped, one motor at a time and then bring them up to speed (the 50 maximum on the force option is not fast enough), and lift the aircraft off the ground.  Next would be to retract the gear and close the bays, and since this is a V22, the engines would rotate from vertical lift to horizontal thrust and the aircraft would depart.
I'd like to get all the different parts working properly with the aircraft sitting in front of me.
If someone can head me in the right direction to get started, I would really appreciate it.
Thanks
Tim
There are surely times when it is good to be stubborn.  Knowing when is the gift of experience.
Threaded View
Threaded View
Forum Post Creating a Perform menu for Props By TimV ( 11 Years Ago )
Forum Post ... By Cricky ( 11 Years Ago )
Forum Post Watch Mark's video tute on this very topic here:-... By primaveranz ( 11 Years Ago )
Forum Post Thanks very much!! Exactly what I was looking for. Tim By TimV ( 11 Years Ago )
Forum Post Hi: No, I didn't give up. I am looking for suggestions on dealing... By TimV ( 11 Years Ago )
Forum Post Ok There is a big difference between moving an object by it's pivot... By TimV ( 11 Years Ago )
Forum Post Each part that rotates needs it's pivot at its point of rotation.... By Rampa ( 11 Years Ago )
Forum Post @rampa Hello and thank you for your input. I had reviewed the manual... By TimV ( 11 Years Ago )
Forum Post Observations In 3DXchange6, I have exported only the items associated... By TimV ( 11 Years Ago )
Forum Post This might be helpful. I'm not sure, but the spinner is the main... By TimV ( 11 Years Ago )
Forum Post I've got an idea what might be going on, as it looks like everything... By Rampa ( 11 Years Ago )
Forum Post @rampa Thanks!!! I did notice the down arrows, but didn't try them.... By TimV ( 11 Years Ago )
Forum Post @rampa Hi. I set everything to local. It still happens. Everything... By TimV ( 11 Years Ago )
Forum Post Hi Went back to Hexagon. created a new prop of a group which is the... By TimV ( 11 Years Ago )
Forum Post Hi: I now have two working prop assemblies which are both animated... By TimV ( 11 Years Ago )
Forum Post Target the propeller's hinge constraint to the motor body rather than... By primaveranz ( 11 Years Ago )
Forum Post @rampa, @primaveranz Thank you both, and yes, primaveranz, I am... By TimV ( 11 Years Ago )
Forum Post [quote][b]TimV (5/31/2015)[/b][hr]@rampa, @primaveranz I have tried... By primaveranz ( 11 Years Ago )
Forum Post Hi Thank you both. I have found that I am more inclined to enter... By TimV ( 11 Years Ago )
Forum Post Further information that just makes sense now. When the model was... By TimV ( 11 Years Ago )
Forum Post If you create one motor and one propeller assembly and it works, hold... By primaveranz ( 11 Years Ago )
Forum Post @primaveranz Thanks. I understand how to clone the object, but in... By TimV ( 11 Years Ago )
Forum Post Doh! Just realized that your hinge may not be in line with your... By Rampa ( 11 Years Ago )
Forum Post You might want to upload the project, as I am out of ideas without... By Rampa ( 11 Years Ago )
Forum Post OK, I do know what is going on with the props not following. The... By Rampa ( 11 Years Ago )
Forum Post Make sure the motors are set to physics activated and kinematic. I... By Rampa ( 11 Years Ago )
Forum Post Not sure why it was not letting you set the hinge target. The motor... By Rampa ( 11 Years Ago )
Forum Post I actually have an osprey model already. It's maybe a little... By Rampa ( 11 Years Ago )
Forum Post @swooooop, Did mine the other day.... By Rampa ( 11 Years Ago )
Forum Post I had to separate the propellers. The original had them as one object.... By Rampa ( 11 Years Ago )
