Iclone 6 Clean install required
Posted By Krusher 11 Years Ago
Krusher
QuestionMark
Krusher
Posted 11 Years Ago
Veteran Member (545 reputation)Veteran Member (545 reputation)Veteran Member (545 reputation)Veteran Member (545 reputation)Veteran Member (545 reputation)Veteran Member (545 reputation)Veteran Member (545 reputation)Veteran Member (545 reputation)Veteran Member (545 reputation)
Posts: 26, Visits: 1.2K
I have finally broken my installation in an attempt to trim my 256GB ssd. Cleaned the registry,deleted files and generally just made a mess of it. On a new install iclone attempts to recover my "unsaved project" If I click O.K crash, if not iclone opens i can create a project but when I go to save anything it crashes.
OS WIN 8.1 16 GB RAM GTX 980 4GB
It seems something is amiss. Do any of you icloners know what to do?:blush::discuss:
Haswell i7-5930K (3.5 GHz, 140W, 15MB Cache)
16GB RAM, 1.0TB SSD, 3.0TB HD
NVIDIA GeForce® GTX™ 980 (X3/SLI) 4GBx3
DxDiag.txt (367 views, 88.00 KB)
Posted 11 Years Ago
Posts: 5.7K, Visits: 26.5K
The "unsaved Project" files are stored in the iClone Temp folder on your PC.
If my memory is correct this folder is stored by default in this path:
C:\Users\Your User Name\AppData\Local\Reallusion
Since the AppData folder is hidden you need to make sure that you have "Show Hidden Folders" selected in the Explorer View settings. Locate the folder and delete all of the files stored in it, this will solve your problem.
If you are having space problems on your system drive then I would also suggest that you place the Temp folder on another drive on your system - you can set the location in the Preferences settings in iClone.
Krusher
Krusher
Posted 11 Years Ago
Thanks Gerry, for being the first to reply.
I did not find a file at the location C:\Users\Your User Name\AppData\Local\Reallusion there are some files at
C:\Users\Your User Name\AppData\Local\Temp\ contains 3 files RLT8908.tmp all blank and a folder RLTMP containing ICBasics and ICContentManager . but I don't know if theses are the correct one's.
Krusher
Krusher
Posted 11 Years Ago
Okay, so I opened a support case in order to resolve this issue and received the following.
Instructions for a clean install are:
It appears that there is a problem with your installation of iClone 6 and/or the data stored in the system registry. To resolve this we have provided you with the 'iClone 6 Registry Remover'.
Please complete the following steps: -
1. Uninstall iClone 6.
2. Download and unzip the attached file.
3. Run "CleanReg.exe"
4. Then Go to "C:\Program Files\Reallusion\" and delete the iClone 6 folder
Note: When you run CleanReg you may get an "Access Denied" error message. If this happens, please right click the Cleanreg.exe and select "Run As Administrator". Thank you
Now download and install the latest full version of iClone 6 which is version 6.02. You can get this from your Member Account.
This may work for some but for me didn't not resolve my issue.
I resorted to a factory reset of my system and have only loaded the required software to continue rendering. I was experimenting with relocating system resources off of C: drive when things went wrong.... morale of this misadventure - get a bigger SSD !
45thdiv
45thdiv
Posted 11 Years Ago
Posts: 209, Visits: 696
Thanks for this post.  Another thing for me to look at when i get home to stop iClone6 from crashing everytime i try to open a save project.
Matthew
PC stats:
Intel Core i7-5930K Processor (6-cores, 15MB Cache, Overclocked to 3.9 GHz with Turbo Boost)
Windows 10
Graphics card NVIDIA GeForce GTX 1080 graphics, 8GB
Memory - 16GB Quad Channel  DDR4 at 2133MHz
DirectX - 12
256GB SSD 6Gb/s main HD + 4TB 6kRPM SATA 6Gb/s Storage
FreddyKrueger
FreddyKrueger
Posted 11 Years Ago
Veteran Member (986 reputation)Veteran Member (986 reputation)Veteran Member (986 reputation)Veteran Member (986 reputation)Veteran Member (986 reputation)Veteran Member (986 reputation)Veteran Member (986 reputation)Veteran Member (986 reputation)Veteran Member (986 reputation)
Posts: 97, Visits: 468
Hey,
I have the exact same problem with my Iclone 6 and I did not mess with any registry files. It looks like there is a corrupt auto save on the system. Deleting the Temp files does absolutely nothing. It seems that there are files outside of the temp folder that may get corrupt and cause all of this crap.
If anybody else has an idea... it would help a ton. Iclone is unusable and the support team, thus far, seems to be clueless.
Alienware 15, i7 4710hq, GTX 970m, 16gb ram, 4k display, 1.5TB SSD raid.
gregsin
gregsin
Posted 11 Years Ago
Last Active: 8 hours ago
Posts: 373, Visits: 1.4K
I have the exact same problem with Iclone crashing when loading a saved project. I created a trouble ticket and sent in a dxdialog. I did what I was told and still had the same problem. I've been able to reload the projects by loading a default project first and then loading the saved project. It doesn't work all the time but most times it does. This happens mostly on larger files. There's got to be a problem with the software as sometimes the file loads and sometimes it doesn't. Also seems like if I wait a few minutes after starting Iclone I have a better chance of the file opening. I hope they get this fixed.
