carlo75
carlo75
Posted 10 Years Ago
Last Active: 10 Years Ago
Visits: 58
Hi all, I'm using DrawPlus for make some custom parts for a character and props, but I see when I'm dealing with Render Styles that my custom draws aren't affected by the change.
Someone can help me to find the right way to draw correctly for Render Style compliance?
Thanks in advance. Best regards.
Ibis Fernandez
Ibis Fernandez
Posted 10 Years Ago
Last Active: 11 Months Ago
Posts: 1.2K,
Visits: 4.3K
Just make sure that your artwork is in vector format. That's all. Once you import,you'll need to set up the render style groups for that item. In the character composer its the button below the renderstyle button.
 Ibis Fernandez | (available for hire) ---------------------------------------------------------------------------------------- Professional Animator, Filmmaker | Creator of the highest quality (modular) G2 rigs for cartoon animator and developer of Toon Titan and Puppet Producer Author of Flash Animation and Cartooning: A Creative Guide >>> be sure to check out http://toontitan.com for professional grade assets, templates, and custom tools for Cartoon Animator and more.
carlo75
carlo75
Posted 10 Years Ago
Visits: 58
Hi Ibis and thanks for your reply, I'll take a look inside Render Style panel...
carlo75
carlo75
Posted 10 Years Ago
Visits: 58
Hi Ibis, I spent a lot of times on vector grouping tool. I 've grouped my head vectors and then apply the Skin01 Name Selection. So, my head became gray as you can see from attachement. Can't figure out where I'm wrong :crying:
Ibis Fernandez
Ibis Fernandez
Posted 10 Years Ago
Posts: 1.2K,
Visits: 4.3K
This might be normal. Depends on what colors they were. Now that you grouped them are you not able to change the color?
carlo75
carlo75
Posted 10 Years Ago
Visits: 58
Hi Ibis, no I can't. I can only change the first parameter "brightness" and it doesn't work very well...
Ibis Fernandez
Ibis Fernandez
Posted 10 Years Ago
Posts: 1.2K,
Visits: 4.3K
Hmm, try doing it again. Make sure you are grouping colors that are the same or similar. I've noticed CTA tries to apply as the group default the last color that was grouped. Also don't group geayscale or black colors with regular colors.
Ibis Fernandez
Ibis Fernandez
Posted 10 Years Ago
Posts: 1.2K,
Visits: 4.3K
Also try applying a style to it via apply renderstyle see if that works.
carlo75
carlo75
Posted 10 Years Ago
Visits: 58
Hi Ibis thanks again for your time, I really appreciate it. Today I'll try again, following your indications. I hope this time, will work, but sincerely I'm a bit dejected
Ibis Fernandez
Ibis Fernandez
Posted 10 Years Ago
Posts: 1.2K,
Visits: 4.3K
it would help if you could record yourself performing this task so i can see what you are doing and can advise better. There a free program called camstudio that you can use.
