How do you remove animations from just one selected body part?
Posted By gongora.animations 11 Years Ago
gongora.animations
gongora.animations
Posted 11 Years Ago
Last Active: 10 Years Ago
Posts: 27, Visits: 220
Hello all,
I'm just wondering if there's a shortcut in CTA2 that allows you to for example, remove any and all animation movements for just one specific body part of a CTA2 character.
Like if I drag and dropped a walking animation to a model but didn't want their arms to move in the walking sequence, could I just select that body part and delete its animations without manipulating key frames directly for each frame, does such a shortcut exist?
Thanks in advance,
Juan
jlittle
jlittle
Posted 11 Years Ago
Posts: 1.9K, Visits: 17.3K
From the Help:
Removing Motions of Body Parts
CrazyTalk Animator provides a lot of built-in motion templates for characters. However, sometimes you maybe need to make small adjustments to specific body parts from motion templates to generate a new custom motion, especially when you need to keep some body parts to be motionless or in an absolute gesture. To do this, you may utilize the Remove Motion feature to remove certain body part motions and add Motion Layer keys.
Removing Body Part Motions from a Motion Clip
  1. Apply any one motion template from library to a character.
  2. Open Timeline (Shortcut: F3). Click the Motion button of the character to show its motion track. You will see that the motion clip is stored inside the track.
  3. Right-click on the clip, select Remove Motion and pick the body part (in this case, the Right Hand) from which you wish to remove motions.
    You may optionally repeat the same steps to remove motions from other body parts.
  4. Play back and the motion of the body part is removed from the original motion clip.
    Right Hand motion removed.
Jeff
gongora.animations
gongora.animations
Posted 11 Years Ago
Thank you Jeff!! :D
akachikalu
akachikalu
Last Active: 7 Years Ago
Posts: 1, Visits: 9
How can i remove a walk animation/sequence from my character?
Posts: 23.1K, Visits: 36.6K
akachikalu (10/30/2019)
Just do the following:
1. Select the character you wish to remove the animation from by clicking it.
2. Press F3 to open the Timeline.
3. Select 3D motion or 2D Motion depending on the character type and motion you have applied.
4. Click on the motion clip you want to remove and hit the Delete key.
5. If you want to remove all animation from your character just right click it and choose "Remove Object Animation".
