iClone 6 for DX-9 Beta is here for your early test
Posted By Visconti 10 Years Ago
Visconti
Visconti
Posted 10 Years Ago
Distinguished Member (49.4K reputation)Distinguished Member (49.4K reputation)Distinguished Member (49.4K reputation)Distinguished Member (49.4K reputation)Distinguished Member (49.4K reputation)Distinguished Member (49.4K reputation)Distinguished Member (49.4K reputation)Distinguished Member (49.4K reputation)Distinguished Member (49.4K reputation)
Last Active: 10 Years Ago
Posts: 1.0K, Visits: 3.0K
Hi, folks
After iClone 6 release, we constantly collected users' feedbacks about the DirectX 11 (DX-11) graphics card compatibility issues. So, our product team has released the beta version of iClone 6 for DX-9 that you can experience at first hand.
This Beta program is designed for any iClone 6 Standard/PRO purchase users who can't run iClone 6 smoothly due to the system limitation (including launch failure, crash, and iClone 5 content compatibility).
With this new update, DX-9 users can still play with iClone 6 and most iClone 5 level content. This would entail limitations of certain DX-11 related features like Displacement, Real-time Smoothing, SpeedTree, limited number of lighting, and partial Indigo support. Please check out the differences.
See the differences
System Requirement http://www.reallusion.com/iclone/iclone_requirements.aspx
Version Comparison http://www.reallusion.com/iclone/iclone_matrix_versions.aspx
Simply download and install the patch below, and you will notice there is a new graphics mode option, and then select "DirectX 9 (Beta)" to test out its performance. You are welcome to leave yourcomments and feedbacks in this thread. Our product team will collect your inputs to build the official version 6.02 as final release.
iClone 6.02 Patch Beta
http://cdn3.reallusion.com/iClone_602_Enu_Patch_beta.exe
(For iClone 6 Standard & PRO purchase users. The trial version will be ready when the official v6.02 is released.)
iClone Render Plugin 1.02 Patch Beta
http://cdn3.reallusion.com/iClone_IRP_102_Enu_Patch_beta.exe
Best
Reallusion, Inc.
Version: v6.02.1316.1 Beta
Added:
. Added iClone DirectX 9 Version for earlier graphic cards.
. Added Graphic Mode Selection for DirectX 9/DirectX 11 switching.
** DX9 Known Issue
. Some checkbox do not work correctly in the Render options of Preference settings.
. Export .igs fails when the scene contains a tree.
. Trees not visible in Mini-viewport.
Fixed:
. Fixed: Hard to select lower eyelid in facial features under Large Font size mode.
. Fixed: In iClone traditional transform gizmo mode, mouse scroll is now camera zoom in/out.
. Fixed: Holding the CTRL key while rotating/scaling an object didn't duplicate correctly.
. Fixed: Anisotropic Filtering in the Preference settings not remembered.
. Fixed: Tone Mapping for Indigo Render Settings, default value changed to unchecked.
. Fixed: Resizing the Infinite Plane caused program to crash.
. Fixed: Some of the content downloads showed Network error (error code 202).
. Fixed: Frame rate disabled unexpectedly while rendering AVI .
Content Update
. G6 Character: Enhanced the skin quality for Indigo rendering.
. Default Project: Default.iProject enhanced shape smoothing on some objects for Indigo rendering.
______________________________________________________
Visconti
Forum Moderator
Reallusion, Inc.
https://forum.reallusion.com
Threaded View
Threaded View
Forum Post iClone 6 for DX-9 Beta is here for your early test By Visconti ( 10 Years Ago )
Forum Post Can you have both DX9 and DX11 coexisting side-by-side? ADDED... By justaviking ( 10 Years Ago )
Forum Post [quote][b]justaviking (1/16/2015)[/b][hr]Can you have both DX9 and... By colour ( 10 Years Ago )
Forum Post [quote][b]justaviking (1/16/2015)[/b][hr]Can you have both DX9 and... By justaviking ( 10 Years Ago )
Forum Post Installed IC 6 standard version and installed patch on my old laptop.... By hattori kun ( 10 Years Ago )
Forum Post It says it's a patch, rather than a whole different version, and you... By Rampa ( 10 Years Ago )
Forum Post @Hattori, make sure you have the latest dx9c version installed... I... By planetstardragon ( 10 Years Ago )
Forum Post [quote][b]rampa (1/16/2015)[/b][hr]It says it's a patch, rather than a... By justaviking ( 10 Years Ago )
Forum Post Ok will check the dx version. Its an old laptop.:D By hattori kun ( 10 Years Ago )
Forum Post I have another PC I can try this on. Is the patch cumulative, or do I... By animagic ( 10 Years Ago )
Forum Post Ok it worked. I just didn't try hard enought to check some stuff and... By hattori kun ( 10 Years Ago )
Forum Post After installing, did you apply both patches or just 6.02? By animagic ( 10 Years Ago )
Forum Post [quote][b]animagic (1/16/2015)[/b][hr]After installing, did you apply... By hattori kun ( 10 Years Ago )
Forum Post The post from Visconti also mentions several fixes... so... Am I... By RobertoColombo ( 10 Years Ago )
Forum Post [quote][b]RobertoColombo (1/16/2015)[/b][hr]The post from Visconti... By justaviking ( 10 Years Ago )
Forum Post [quote][b]RobertoColombo (1/16/2015)[/b][hr]The post from Visconti... By Peter (RL) ( 10 Years Ago )
Forum Post HI Dennis, in fact I can run smoothly with DX11, so I do not need... By RobertoColombo ( 10 Years Ago )
Forum Post I assume the official release of 6.02 will include a list of fixes.... By justaviking ( 10 Years Ago )
Forum Post [quote][b]justaviking (1/17/2015)[/b][hr]I assume the official release... By Peter (RL) ( 10 Years Ago )
Forum Post Thanks Peter for the clarification! I will wait for the official 6.02... By RobertoColombo ( 10 Years Ago )
Forum Post Repeating Animagic's question... Is 6.02 cumulative, meaning in... By justaviking ( 10 Years Ago )
Forum Post [quote][b]justaviking (1/17/2015)[/b][hr]Repeating Animagic's... By Bellatrix ( 10 Years Ago )
Forum Post The graphics mode selection is as below By Visconti ( 10 Years Ago )
Forum Post [b]Basic Questions for iClone 6 PRO[/b] My PC has nVIDIA Quadoro FX... By hirospot ( 10 Years Ago )
Forum Post ヒロさん, はじめまして 前のポスト テストしてください Switcher in the folders. Maybe RL... By hattori kun ( 10 Years Ago )
Forum Post @ hattori kun Thank you for your response. 初めまして、ご支援をありがとうございます。... By hirospot ( 10 Years Ago )
Forum Post I thought I would add the following I am unable to run Iclone 6 on... By videodv ( 10 Years Ago )
Forum Post Fast list of issues after this patch: At least one new: iClone has... By madicloner ( 10 Years Ago )
Forum Post I believe I belong to the "Neutral area" ( no, I am not from... By RobertoColombo ( 10 Years Ago )
Forum Post Bug after installing this patch to standard version Missing... By hattori kun ( 10 Years Ago )
Forum Post @hattori kun: I don't have the Standard version. Were the animation... By animagic ( 10 Years Ago )
Forum Post Only affects standard afaik. Pro 601->602 is ok. The search function... By hattori kun ( 10 Years Ago )
Forum Post [quote][b]hattori kun (1/22/2015)[/b][hr]Only affects standard afaik.... By Peter (RL) ( 10 Years Ago )
Forum Post Bug found in IC6.02xxx: spring no longer works after resizing Avatar ... By Supergerry ( 10 Years Ago )
Forum Post QUESTION TO DX9 USERS... I'm curious, has this patch been a good... By justaviking ( 10 Years Ago )
Forum Post [quote][b]justaviking (1/25/2015)[/b][hr]QUESTION TO DX9 USERS... Do... By justaviking ( 10 Years Ago )
Forum Post [quote][b]justaviking (2/1/2015)[/b][hr][quote][b]justaviking... By colour ( 10 Years Ago )
Forum Post Hi Colour... I thought you bought iC6, and then found out your... By justaviking ( 10 Years Ago )
Forum Post Haven't had time to try it. Slow down a bit.:P By lesdodds ( 10 Years Ago )
Forum Post If there's a next patch I would test it. I'm skipping this one because... By hattori kun ( 10 Years Ago )
Forum Post 6.02 standard dx9 Lounge scene instant crash when opening Iclone... By hattori kun ( 10 Years Ago )
Forum Post BUG FOUND IN IC6.02BETA (DX11): Deleting Motion from Bodyparts in... By Supergerry ( 10 Years Ago )
Forum Post I guess there are more IC6 users with adequate computers using dx 11... By hattori kun ( 10 Years Ago )
Forum Post [quote]I noticed you would be giving up a lot of dx 11... By colour ( 10 Years Ago )
Forum Post I had to rebuild my old All in One computer and am putting iClone5... By KenCoon ( 10 Years Ago )
Forum Post Ken, the Beta is expired now, because 6.02 has been officially... By animagic ( 10 Years Ago )
Forum Post Do I need to install iClone6 first or just install 6.02 and use that?... By KenCoon ( 10 Years Ago )
Forum Post [DX 9 Mode Selection Report] Here is my DX 9 Mode Selection Report... By hirospot ( 10 Years Ago )
Forum Post bonjour a tous demande une aide je n'arrive pas a mettre a jour ma... By stephane.besnard05 ( 10 Years Ago )
Forum Post [quote][b]stephane.besnard05 (12/29/2015)[/b][hr]bonjour a tous... By Peter (RL) ( 10 Years Ago )
