iClone 6 for DX-9 Beta is here for your early test
Posted By Visconti 10 Years Ago
3
4
5
Visconti
Visconti
Posted 10 Years Ago
Distinguished Member (49.4K reputation)Distinguished Member (49.4K reputation)Distinguished Member (49.4K reputation)Distinguished Member (49.4K reputation)Distinguished Member (49.4K reputation)Distinguished Member (49.4K reputation)Distinguished Member (49.4K reputation)Distinguished Member (49.4K reputation)Distinguished Member (49.4K reputation)
Last Active: 10 Years Ago
Posts: 1.0K, Visits: 3.0K
Hi, folks
After iClone 6 release, we constantly collected users' feedbacks about the DirectX 11 (DX-11) graphics card compatibility issues. So, our product team has released the beta version of iClone 6 for DX-9 that you can experience at first hand.
This Beta program is designed for any iClone 6 Standard/PRO purchase users who can't run iClone 6 smoothly due to the system limitation (including launch failure, crash, and iClone 5 content compatibility).
With this new update, DX-9 users can still play with iClone 6 and most iClone 5 level content. This would entail limitations of certain DX-11 related features like Displacement, Real-time Smoothing, SpeedTree, limited number of lighting, and partial Indigo support. Please check out the differences.
See the differences
System Requirement http://www.reallusion.com/iclone/iclone_requirements.aspx
Version Comparison http://www.reallusion.com/iclone/iclone_matrix_versions.aspx
Simply download and install the patch below, and you will notice there is a new graphics mode option, and then select "DirectX 9 (Beta)" to test out its performance. You are welcome to leave yourcomments and feedbacks in this thread. Our product team will collect your inputs to build the official version 6.02 as final release.
iClone 6.02 Patch Beta
http://cdn3.reallusion.com/iClone_602_Enu_Patch_beta.exe
(For iClone 6 Standard & PRO purchase users. The trial version will be ready when the official v6.02 is released.)
iClone Render Plugin 1.02 Patch Beta
http://cdn3.reallusion.com/iClone_IRP_102_Enu_Patch_beta.exe
Best
Reallusion, Inc.
Version: v6.02.1316.1 Beta
Added:
. Added iClone DirectX 9 Version for earlier graphic cards.
. Added Graphic Mode Selection for DirectX 9/DirectX 11 switching.
** DX9 Known Issue
. Some checkbox do not work correctly in the Render options of Preference settings.
. Export .igs fails when the scene contains a tree.
. Trees not visible in Mini-viewport.
Fixed:
. Fixed: Hard to select lower eyelid in facial features under Large Font size mode.
. Fixed: In iClone traditional transform gizmo mode, mouse scroll is now camera zoom in/out.
. Fixed: Holding the CTRL key while rotating/scaling an object didn't duplicate correctly.
. Fixed: Anisotropic Filtering in the Preference settings not remembered.
. Fixed: Tone Mapping for Indigo Render Settings, default value changed to unchecked.
. Fixed: Resizing the Infinite Plane caused program to crash.
. Fixed: Some of the content downloads showed Network error (error code 202).
. Fixed: Frame rate disabled unexpectedly while rendering AVI .
Content Update
. G6 Character: Enhanced the skin quality for Indigo rendering.
. Default Project: Default.iProject enhanced shape smoothing on some objects for Indigo rendering.
______________________________________________________
Visconti
Forum Moderator
Reallusion, Inc.
https://forum.reallusion.com
Posted 10 Years Ago
Posts: 8.2K, Visits: 26.5K
Can you have both DX9 and DX11 coexisting side-by-side?
ADDED LATER...
CLARIFICATION... I meant can you have the DX9 version of iClone 6 and the DX11 version of iClone 6 both installed at the same time, like we can with iC4, iC5, and iC6
Or does this overwrite the DX11 installation [of iClone]?  If so, then if you upgrade your graphics card later will you have to uninstall and reinstall iClone to start using the DX11 version [of iClone]?
Lastly... Although I expressed concern that this would be a distraction that diverts development resurces from working on fixes and enhancements to DX11-iClone 6, I am pleased that Reallusion **DOES** pay attention to their user base.
hattori kun
hattori kun
Posted 10 Years Ago
Distinguished Member (6.9K reputation)Distinguished Member (6.9K reputation)Distinguished Member (6.9K reputation)Distinguished Member (6.9K reputation)Distinguished Member (6.9K reputation)Distinguished Member (6.9K reputation)Distinguished Member (6.9K reputation)Distinguished Member (6.9K reputation)Distinguished Member (6.9K reputation)
Posts: 868, Visits: 4.1K
Installed IC 6 standard version and installed patch on my old laptop.
Failure to initialize same as the pro version. I can't launch to see the dx 9 boot selection.
System spec
I7 720qm
Geforce gt330 driver 340.52
8gb ram
windows 7 64 sp1
Nvidia 330m supports dx 10 and shader model 4.0. Launched with admin rights. Should've work :D
http://www.geforce.com/hardware/notebook-gpus/geforce-gt-330m/features
colour
colour
Posted 10 Years Ago
Distinguished Member (12.1K reputation)Distinguished Member (12.1K reputation)Distinguished Member (12.1K reputation)Distinguished Member (12.1K reputation)Distinguished Member (12.1K reputation)Distinguished Member (12.1K reputation)Distinguished Member (12.1K reputation)Distinguished Member (12.1K reputation)Distinguished Member (12.1K reputation)
Posts: 5.2K, Visits: 8.1K
justaviking (1/16/2015)
Or does this overwrite the DX11 installation?  If so, then if you upgrade your graphics card later will you have to uninstall and reinstall iClone to start using the DX11 version?
My question too, Dennis. Since W7 OS is DX11, which in theory is backwards compatible & my GPU is DX11, but iC5 Installer, Installs MS DX9. Is it that only iC5 is DX 9 & other Imaging Applications eg; Photoshop, Pinnacle Studio, remain DX11?
Posted 10 Years Ago
CLARIFICATION... I meant can you have the DX9 version of iClone 6 and the DX11 version of iClone 6 both installed at the same time, like we can with iC4, iC5, and iC6.
Posted 10 Years Ago
Posts: 8.2K, Visits: 62.5K
It says it's a patch, rather than a whole different version, and you choose either 9 or 11 when you run the program.
So, no co-running iC6's I should think. But I use 5 and six together all the time (working on avatars), so DX9 andDX11 are certainly co-existing. :)
planetstardragon
planetstardragon
Posted 10 Years Ago
Distinguished Member (24.1K reputation)Distinguished Member (24.1K reputation)Distinguished Member (24.1K reputation)Distinguished Member (24.1K reputation)Distinguished Member (24.1K reputation)Distinguished Member (24.1K reputation)Distinguished Member (24.1K reputation)Distinguished Member (24.1K reputation)Distinguished Member (24.1K reputation)
Posts: 11.5K, Visits: 46.0K
@Hattori, make sure you have the latest dx9c version installed... I had to install it manually way back when.
"To define Tao is to defile it" - Lao Tzu
Posted 10 Years Ago
rampa (1/16/2015)
I thought the "DX9/11" choice was when you were installing the patch, not while launching iClone every time.
Reading it more carefully, it sounds like it's a "preference" you can set inside iClone once you've launched it.  If that's the case, how does it help people who can't even get it to launch start correctly?  I'm kind of back to it being a choice you make while installing the patch.
So you can toggle back-and-forth between them anytime you want?
REALLUSION --- Please clarify.
(I'm easily confused, so type slowly.)
hattori kun
hattori kun
Posted 10 Years Ago
Ok will check the dx version. Its an old laptop.:D
Posted 10 Years Ago
Posts: 15.8K, Visits: 31.3K
I have another PC I can try this on. Is the patch cumulative, or do I have to apply 6.01 first?
3
4
5
