Posted 10 Years Ago
Posts: 15.8K,
Visits: 31.4K
That's why I suggested to backup the registry data for iClone 6. It this point your best bet is indeed to reinstall. Make sure to be connected to the internet when you uninstall. That why you preserve your installation seat (you can install on two computers). During installation you will be asked for the location of your Template and Content folders. In your case I would select to have both on a drive other than your C:\ drive.
Dongoch
Dongoch
Posted 10 Years Ago
Last Active: 10 Years Ago
Visits: 21
wires (1/13/2016)
Permissions is a Windows setting. You should check the Security settings under the drive properties tab to ensure that you have full rights to access the drive in question. Depending on your version of Windows you may need to use Administrator rights to make any changes. Hey wires, I dont think that there is a problem on drive permissions. I think problem is something else. Kelleytoons (1/13/2016) Most likely you made a mistake in your edit of the registry -- you'd need to provide that for anyone to help (just a screen printout of what the registry says for those entries would be sufficient).
Kelleytoons thank you for reply. Yes, maybe I made mistake in my edit of the registry. But i didn't take backup of registry folder. I am going to reinstall iclone. Thank you!
rampa (1/13/2016) When I wanted them in a different location, I just re-installed iClone. Since it lets you define where they go during installation, it was pretty painless.
To feel even more secure about doing that, you could rename, or back-up, the existing folders first.
Hey rampa, ty for reply. Can we chose the location of the template folder during installation? I didn't realize that. I am going to reinstall and set the templete folder during installation. Thank you very much!
Posted 10 Years Ago
Visits: 62.6K
Posted 10 Years Ago
Visits: 22.1K
Posted 10 Years Ago
Posts: 5.7K,
Dongoch
Dongoch
Posted 10 Years Ago
Visits: 21
Hello, I have same problem. I have SSD (solid state drive) harddisk as C:\ drive and and ist only 128 GB harddisk space. I want to move iclone template folder to my D:\ drive. I did what you said but when I launch iclone6 it says "Pack view is disabled, you don't have permission to write file(s) in /template custom path", and doesn't show anything on the content. Can anyone help me? Thank you!
Posted 11 Years Ago
Posts: 15.8K,
Visits: 31.4K
I'm glad it worked. Writing it down it felt very complicated...:unsure: This has in fact been a feature request.
hattori kun
hattori kun
Posted 11 Years Ago
Visits: 4.1K
Thanks! I edited the registry and then manually copied over the content files. No problems so far. Fingers crossed. Maybe a good request to have is the ability to set the content directory by a user. Just like the ability to set temp files, etc.
Posted 11 Years Ago
Posts: 15.8K,
Visits: 31.4K
I was going to suggest that the easiest way to make these changes is to edit the backup registry file you saved earlier. Save that modified file under a new name, and double-click to apply the changes. Each value is on a separate line. You would keep the lines that specify the Custom and Template folders and change the path and delete the rest. Suppose your new Reallusion root is "D:\Reallusion". You would then change the value for Template Data (I'm not quite sure what the default root is...), for example, as follows: "Template Data"="C:\\Users\\Public\\Public Documents\\Reallusion\\Template\\iClone 6 Template" becomes: "Template Data"="D:\\Reallusion\\Template\\iClone 6 Template"
And, of course, don't forget to move your content. ;) I hope this is clear. If not, ask...
Posted 11 Years Ago
Posts: 15.8K,
Visits: 31.4K
Are you willing/able to edit the registry? That is currently the only way to do it. - Launch regedit.exe.
- Navigate to the key HKEY_LOCAL_MACHINE\SOFTWARE\Reallusion\iClone\6.0.
- As a safeguard you can make a backup at this point. Right-click on the 6.0 key and select Export. You will be prompted for a name and a location for a registry file that will store the current values.
- Under the 6.0 key, you will so all kinds of values listed on the right.
- You are looking for folder locations that have "Reallusion\Custom\iClone 6 Custom" or "Reallusion\Template\iClone 6 Template" in the path as that is where your data is located.
- There is also "Reallusion\Shared Custom" and "Reallusion\Shared Template", but these are relatively small so it's probably best to leave them.
- Decide on a new location for your Custom and Template data and update the registry values accordingly.
OK, I notice it's past my bedtime...:doze: so I'll have to get back to this...:crazy:
