New bug with iclone 5.5 saving projects with trees
Posted By Lentamente 10 Years Ago
Lentamente
Lentamente
Posted 10 Years Ago
Veteran Member (643 reputation)Veteran Member (643 reputation)Veteran Member (643 reputation)Veteran Member (643 reputation)Veteran Member (643 reputation)Veteran Member (643 reputation)Veteran Member (643 reputation)Veteran Member (643 reputation)Veteran Member (643 reputation)
Last Active: 8 Months Ago
Posts: 12, Visits: 474
I will do that. Thank you so much for trying to help me :) I appreciate it a lot :D
colour
colour
Posted 10 Years Ago
Distinguished Member (12.1K reputation)Distinguished Member (12.1K reputation)Distinguished Member (12.1K reputation)Distinguished Member (12.1K reputation)Distinguished Member (12.1K reputation)Distinguished Member (12.1K reputation)Distinguished Member (12.1K reputation)Distinguished Member (12.1K reputation)Distinguished Member (12.1K reputation)
Posts: 5.2K, Visits: 8.1K
Lentamente (1/5/2015)
To be sure, I tried the 4 different ways to save a project: with the +, with the button, with the pop up menu and with the drop down menu: ans the result is always the same... :(
OK
Is it just Trees?
What about Grass or any other Prop or Test Project?
I'm stumped & have run-out of ideas.
Basically; you can Open & Save stuff, but it doesn't show in the Viewport if you re-Open it. But it does show in Scene Manager.
All I can suggest now, is that you send Reallusion a Support "Ticket", quoting the above.
I'll include a Link re; how to do that, if & when I can find it.
ADDED - Link: https://forum.reallusion.com/Topic55-13-1.aspx
You might have to wait a bit for a Reply, because Reallusion are currently overwhelmed with resolving iC6 problems.
Good luck :)
Lentamente
Lentamente
Posted 10 Years Ago
colour
colour
Posted 10 Years Ago
If it is a new project, it shows, as in any other cases. But once the project is saved and I reopen it, it dosn't show, even with the home button.
Have you tried Project / Save Button & Tools Drop-down / Save Project ?
Either way, when you Close iclone, don't Select Save Project again, in the following Pop-up. Select No..
I'm in the UK. It's well-past my bed time ;)
Lentamente
Lentamente
Posted 10 Years Ago
P.S. In some of the 3D scenes I bought earlier from Reallusion, I have the same problem, even if it isn't scenes that I saved recently: in some of the scenes of the pack World Wildness, I can't see the trees anymore, but in others, I still can see them.
Lentamente
Lentamente
Posted 10 Years Ago
colour
colour
Posted 10 Years Ago
Lentamente (1/4/2015)
I've made 2 screenshots to show the problem and the parameters.
OK
1) Select "American Elm" in Content Manager & then Tool Bar Home Icon, to see if it shows.
2) If it does, Select any Object. Place that on the World Axis & Link American Elm to that. Select  "Position", in following Pop-up. If it then shows, un-link it & Delete the Object.
Lentamente
Lentamente
Posted 10 Years Ago
Lentamente
Lentamente
Posted 10 Years Ago
My drivers are all updated. I'm saving my projects in the default directory, but I tried saving them on my desktop and it didn't change a thing. Opening the projects with quick shading, smooth shading or wireframe does not change a thing. This problem is a real mistory to me, since I didn't have it before...
Lentamente
Lentamente
Posted 10 Years Ago
Here are the details:
XPS 730X Intel Core3 I7-975
Nvidia GeForce GTX 295 SLI
12GoMulti-Canal DDR3 à 1066mHz
Windows 7 64 bit
I still have 158 Go available
All the drivers are up to date.
I have this problem only with trees and it doesn't make sense at all:
I didn't have it before. I still can see the trees I add to a scene, animate them and make a render. I just cant't save them in a project or a 3D scene. If I do, though, I will see them appear on the thumbnail, but they won't appear in the scene when I open the project...
