BlueAlert
BlueAlert
Posted 10 Years Ago
Last Active: 10 Years Ago
Visits: 31
Unless I am missing something, I am having the same problems that was discussed in 2012, really. I purchased content and I went for the Premium member plus content and nothing shows up in the program. Also, when you go where directed - no download links to get the promised content. I should not feel bad, since I purchased a training video of clips that are available on the site. I guess I am really special.
Posted 10 Years Ago
Posts: 23.1K,
Visits: 36.6K
What did you purchase? Just let me know and I'll point you in the right direction. :)
BlueAlert
BlueAlert
Posted 10 Years Ago
Visits: 31
Thanks Peter, I have been piecing together a plan to get up and running, but the list of my purchase is as follows: Crazy Talk7 Pro -Social Emoticon -Auto Animation Lib Vol1 -Facial Expression clips Vol2 -Natural Facial Performances Vol2 -Organic Auto Motions Samplers -TTS on Demand Basic Crazy Talk7 Training Business Avatar Bouncy Buddies On my Download info I have links and believe I did install them - do not see them in my program Thanks again.
Posted 10 Years Ago
Posts: 23.1K,
Visits: 36.6K
As you are having problems with multiple packs, please check the example below. This will let us know if the content is actually missing from your installation. In CrazyTalk 7 try switching to the "Actor" tab, then double click "01_Model", then the "Business Avatars Vol.1" folder. This should then display the contents of the pack as shown below. Do you have this folder?
BlueAlert
BlueAlert
Posted 10 Years Ago
Visits: 31
Thanks Peter, I do have what you have posted. I also found out that if I do not have an actor on the work area - I do not get the other content. Discovery learning, I guess. Using your example and having an actor on the work space, I went and checked further. So Actor - Auto Motion -> Functional 4 folders and 15 motions - Folders are inactive and the 15 motions outside the folder are in active is that normal.
Posted 10 Years Ago
Posts: 23.1K,
Visits: 36.6K
BlueAlert (1/9/2015) So Actor - Auto Motion -> Functional 4 folders and 15 motions - Folders are inactive and the 15 motions outside the folder are in active is that normal.Make sure you add a voice to your character first. Once a voice script has been created, everything under Auto Motion > Functional will become active. So to clarify Auto Motions require a voice script be present but Motion Clips can be added without a voice. I hope this helps. :)
