Is there a way to directly edit colors for set items within Iclone?
Posted By corthew 10 Years Ago
corthew
corthew
Posted 10 Years Ago
Last Active: 9 Years Ago
Posts: 59, Visits: 372
The project I want to do takes place on a world with a red dwarf sun.
The plants need to be darker toward the red to benefit from the lower spectrum light.
For some things
********SYSTEM SPECS********
Motherboard - Maximus Hero
Processor - Intel Core i7-4790s 3.2GHz 64 bit Quad-Core Processor
Graphics - MSI GTX 970 4GD5T OC GeForce GTX 970 4GB
Memory - 32GB DDR3 1600 Memory
Storage - SSD main drive + 4 - 1TB 7200RPM Hard Drives
Pending storage - 1 - 4TB Hard Drive
Power Supply -Antec 750W
Operating system - Windows 8.1 Operating System
Case - IN WIN GR one Black Black SECC Full Tower
To run - Iclone 6.0 - 3DXchange Pro 5.51 - Facial Pipeline - Daz3D 4.6
Posted 10 Years Ago
Last Active: 4 hours ago
Posts: 8.1K, Visits: 60.6K
Ironically, you can do this for everything but the plants in iClone 5. In iC6, we should be able to work with the plant textures as well.
If your bringing in alien plants as your own props, then you will have the ability to edit their textures. The current crop of iTrees are strangely limited versions of old Speedtrees. The iC6 trees will be "proper" Speedtrees.
Anyway, select your prop or avatar and find the "Adjust Color" and "Material" sections. Select the tile for the "diffuse" color (upper left tile) and then use the color adjust sliders in the "Adjust Color" section to change the hew and brightness.
You can also set the underlying material color to change the colors. Usually the material is set to white or light gray, but can be set to anything.
corthew
corthew
Posted 10 Years Ago
I'm really looking forward to 6.
Thanks.
Posted 10 Years Ago
Yeah. I'm sitting here in the doldrums waiting.BigGrin As are many of us.
10 Years Ago by rampa
