Where is Composer Mode???
Posted By JuLeeYa 12 Years Ago
jlittle
jlittle
Posted 10 Years Ago
Posts: 1.9K, Visits: 17.3K
Take your actor to Composer Mode.
Select the bone and it will turn blue with a Blue box around it.
Use the handles on the box to size and rotate the bone.
Note that the sprites attached to that bone will size/move/rotate with it.
To align/size/rotate sprites to the bone use the sprite editor.
Select the bone and open the sprite editor and a Green box will appear around the sprite selected.
Adjusting the handles affects ONLY the sprite shown.
If you have multiple sprites for that bone you must adjust each one separately.
If you have multiple angles for that bone you must adjust the sprite(s) for each angle separately.
Jeff
daniel_78
daniel_78
Posted 10 Years Ago
Last Active: 10 Years Ago
Posts: 1, Visits: 2
happen to me that I can not move the points of the bones. Could you tell me that keys have to? I Crazy Talk Animator 2 Pro.
My name is Daniel.
I own drawing I have to animate. Do I have to separate arms, body, head and legs? Or in a single drawing you can make the animation? Thank you
jlittle
jlittle
Posted 12 Years Ago
Place an actor on the stage.
Make sure the actor is selected (red box around it).
Click on the Composer button at the top of the left side tool bar.
You will then be in Composer Mode with that actor.
Jeff
JuLeeYa
JuLeeYa
Posted 12 Years Ago
Veteran Member (871 reputation)Veteran Member (871 reputation)Veteran Member (871 reputation)Veteran Member (871 reputation)Veteran Member (871 reputation)Veteran Member (871 reputation)Veteran Member (871 reputation)Veteran Member (871 reputation)Veteran Member (871 reputation)
Last Active: 11 Years Ago
Posts: 3, Visits: 12
OK CrazyTalk you got me. I am upset and crying. I read in the instruction book to go to Composer Mode for the color editor. But please, please, please, please tell me where-where-where is the Composer Mode. My screen says Stage Mode and I click on that nothing happens. I am customed to a simple menu with listings of what you use. I am frustrated, tired, miserable, why me and crying. I don't like it.:crying:
