alanchen (11/11/2014)
What need to be done:
1) Please refer to the Google Sheet and see if your contents are impacted. If yes, please re-upload them (DO NOT replace, which doesn't work in this case) and update your pack if necessary.
https://docs.google.com/spreadsheets/d/1uRFh87C0f5ZFM0qxT43el8zkl9CST3pPnQ7nXg17VJ4/edit?usp=sharing2) Currently those impacted contents are kept in case you need to retrieve product image or description, etc. When the new uploads are done, you can drop me a mail (alanchen at reallusion。com) to check if the new files are correctly renamed, or delete impacted contents.
3) If the content were purchased before fixed, you can use "Send gift" from "Send message" to send the updated version to the purchaser.
Unfortunately, I am a bit confused and would appreciate some clarification.....
I received a list of the following "impacted items":
| Casserole.iprop |
| CranberrySauce.iprop |
| PumpkinPie.iprop |
| BreadPlate.iprop |
| Fork.iprop |
| spoon.iprop |
| DiningChair.iprop |
| DiningRoom.iprop |
| Hutch.iprop |
So I downloaded the pack and checked every item in iClone 5. The casserole, cranberry sauce, pumpkin pie, fork, spoon, dining room and hutch installed correctly with the correct iProp & correct thumbnails.
The bread plate, and dining chair had the wrong iProp and the wrong thumbnail.
So my questions are as follows:
1. Do I need to re-upload everything on the list or just the items that are "messed up".
2. Once I re-upload what has to be renamed and re-uploaded, I am assuming I have to add these items to the pack.... as purchases have been made already and we can't replace, I am making the assumption that when I send you the email, I should outline specifically which iProp files should be deleted from the pack. Is this correct?
3. Also - Is there an issue with pack items being uploaded for new packs today? Should we insure that any new item has a very unique name?
I apologize for this, but I would rather make sure I am making the appropriates corrections the first time than make a mistake & have to go through the process again.
Thank you for your patience & your time.
Warmest regards,
Granny J
iClone Certified Content Developer and Author of the Pinky Frink® Adventure Series & the Pinky Frink® Learning Books
site: Granny J's 3D Attic SKYPE = grannyjsplace email: grannyj@grannyjs3dattic.com
MY RIG: GPU: Dual GeForce GTX 970M | CPU: Intel(R) Core(TM)i7-5930K @3.50GHz| 32.00 GB RAM | OS: Win 7 Pro SP1 | DX11
