jeremie.coste
jeremie.coste
Posted 12 Years Ago
Last Active: 8 Years Ago
Visits: 302
Hi, I looking forward to get the best way to get a bouncing animation effect on props ? Thanks in advance for your answers, Best regrads, Jérémie
Visits: 3.7K
1. Use Infinite Plane Physics Prop, then place Plane_B Prop into your scene. 2. Place Ball Prop into scene like the image shows, add Soft Physics Preset 4-6 to the prop. 3. Press Play Button, adjust physics property to desired effect. Or you can key frame it using squash & stretch animation principles.;):hehe::D Hope this helps.:w00t::w00t::w00t:
---------------------------------------------------------------------------------------------- Reallusion iClone & CC Pipeline --- Plugins: Iray HeadShot SkinGen. CrazyTalk Animator Pipeline, CrazyTalk, Maya LT, Daz, Substance Painter Indie, Substance Designer Indie, B2M Pro+ Substance Live, Sculptris, Wrap, Unity, UE4, Perception Neuron Ready:):D:P;):cool::hehe::smooooth::crazy::satisfied::Wow::pinch::exclamation::alien::discuss::kiss::arrow::(:angry::sick::exclamation::blush::Whistling::w00t::w00t::w00t: SurfaceBook 2 Windows 11 Pro 64-bit Intel(R) Core(TM) i7-8650U CPU @ 1.90GHz -2.11 GHz 512GB Solid State Hard Drive 8GB RAM Nvidia GeForce 1050GTX Dell Alienware m18X R2 18.5" Custom Convertible Tablet Windows 8.1 Pro 64-bit Intel Core I7-3840QM 2.80GHz Quad Core 8 Thread 3.2GHz Turbo 512GB Solid State Hard Drive+1TB X2 RAID Disk Drive 32GB RAM Nvidia Geforce GTX 680m 2GB X2 SLI Custom Multi-touch. Dagi capacitive touch stylus Microsoft Surface Pro 2 10.1" Tablet Windows 10 64-bit Intel Core I5-4200U 1.60GHz 2.3GHz Turbo 128GB Solid State Hard Drive 4GB RAM HD 4000 Graphics Multi-touch Wacom Digitizer screen Surface Pen+Axiotron Studio Pen Asus Vivo Tab 8" Tablet Windows 10 32-bit Intel Atom Z-3740 1.33GHz Quad Core 32GB Solid State Hard Drive 2GB RAM HD 4000 Graphics Multi-touch Wacom Digitizer Wacom stylus.
jeremie.coste
jeremie.coste
Posted 12 Years Ago
Visits: 302
Thanks !
And in crazytalkanimator2, does the only way is to use keyframe and scale ?
Visits: 3.7K
Opps sorry wrong program, unfortunately I don't own CTA, but I'm sure the squash and stretch principle applies.
1. On ascent and descend the object should be elongated vertically(stretch) 2. upon contact with the ground the object should be elongated horizontally(squash) 3. Only at the height of of the ascent and after being squashed on the ground, should the object take it's normal state.
This technique can also be applied to objects travelling horizontally to cause the illusion of speedy movements or give objects weight.;):cool:
I hope I was simplistic in explaining this invaluable traditional animation technique, for further study google: 12 principles of animation.:w00t::w00t::w00t:
Ibis Fernandez
Ibis Fernandez
Posted 12 Years Ago
Posts: 1.2K,
Visits: 4.3K
It really depends what you are trying to bounce. Squash and stretch is a nice cheat but it doesn't apply to everything. The principle of slow-in and slow out (ease in and ease out), will get you better results. Or combination. The main thing to keep in mind is that the faster an object travels the less frames it needs to display it. The slower the motion, the more frames you need to display it. So play with the easing in an out. For example when a ball falls it picks up speed. As it bounces up it gradually loses speed until gravity wins and starts to pull down on it again.
 Ibis Fernandez | (available for hire) ---------------------------------------------------------------------------------------- Professional Animator, Filmmaker | Creator of the highest quality (modular) G2 rigs for cartoon animator and developer of Toon Titan and Puppet Producer Author of Flash Animation and Cartooning: A Creative Guide >>> be sure to check out http://toontitan.com for professional grade assets, templates, and custom tools for Cartoon Animator and more.
jeremie.coste
jeremie.coste
Posted 12 Years Ago
Visits: 302
Thanks for your advises from iClone to CTA2 ! I will bounce animation like charm, for sure ! Best regards!
