For anyone interested in a solution to this problem I have figured it out - but I would never have achieved it without a lot of help from duchess110. We've spent the past few days exchanging PMs and - EURIKA - we have the answer. :)
This only applies to users who do not have their content stored in the iClone default location which is:
C:\Users\Public\Documents\Reallusion\Template\iClone 5 Template\
The first thing that needs to be done is to make sure that the avatar in question has a persona available. If there is no persona associated with the Avatar, then save it by right clicking and selecting Export Persona from the menu, the file will be saved as a .lua.
Exit iClone and locate the file that was just saved, in my case it is in:
H:\IC5\Custom\iClone 5 Custom\Persona\
Right click on the lua file and select "Open With", I opened my file in Word Pad.
Scroll down the file until you find the motion path for the first motion, it should look like this:
Clips = {
AnimationClip = {
[ 1 ] = {
ID = "2LegsBiteAttack";
TargetType = "Character";
TargetNode = "$";
ClipType = "Motion";
ClipLocation = "C:\\Users\\Public\\Documents\\Reallusion\\Template\\iClone 5 Template\\iClone Template\\Motion\\BEAR\\2LegsBiteAttack.iMotion";
ZeroRoot = true;
Priority = {
[ 1 ] = {
ID = "01";
Node = "$";
Value = 200.000000;
Change the "ClipLocation" line to this:
ClipLocation = "$\\iClone Template\\Motion\\BEAR\\2LegsBiteAttack.iMotion";
This needs to be done for every motion listed in the file.
Look at the path carefully and make sure to remove only the following, and replacing the C with a $:
When all is done save the file, open iClone, select your Avatar and import the persona that you saved. Now the right click menu will work as it should. :cool:
Once again many thanks to duchess110 - Linda, for taking the time to help me sort this out. :kiss:
