rebitmusic
rebitmusic
Posted 10 Years Ago
Last Active: 10 Years Ago
Visits: 10
Did you add the 'audio listener' component to your camera ?
matt_20150223135840676
Posted 10 Years Ago
Visits: 50
Peter (RL) (8/25/2014) If you have contacted Support then you should hear back soon. Support will normally reply within 48 hoursMonday to Friday. If you submitted your question over a weekend it will take a little longer to get a reply. Hopefully they will be able to help you resolve the problem quickly.Would really be better to reply on this forum, that way everyone can benefit from the question being answered. I'm going to have to bother support with the same question myself now...
Posted 11 Years Ago
Posts: 23.1K,
Visits: 36.6K
If you have contacted Support then you should hear back soon. Support will normally reply within 48 hours Monday to Friday. If you submitted your question over a weekend it will take a little longer to get a reply. Hopefully they will be able to help you resolve the problem quickly.
obstacledelusions
obstacledelusions
Posted 11 Years Ago
Last Active: 11 Years Ago
Visits: 4
I have a couple of characters brought into Unity from CrazyTalk 7, using the interactive plugin, and when I load the characters from an assetBundle, the animations work, but no audio comes out. The characters, and their scripts work fine in the project in which they were originally authored.
It's also worth noting that when I pause the app that has loaded the crazyTalk characters, I get this weird error:
ArgumentOutOfRangeException: Cannot be negative. Parameter name: length System.String.Substring (Int32 startIndex, Int32 length) (at /Users/builduser/buildslave/mono-runtime-and-classlibs/build/mcs/class/corlib/System/String.cs:348) CUnityGUIFunction.ChangeFolderPath (UnityEngine.GameObject[] kCTActors) A.. (UnityEngine.GameObject[] ) Autorun.DoPlayModeChange () UnityEditor.EditorApplication.Internal_PlaymodeStateChanged () (at C:/BuildAgent/work/d63dfc6385190b60/artifacts/EditorGenerated/EditorApplication.cs:308) UnityEditor.Toolbar:OnGUI()
The error only happens when I pause. Not sure what it means, but I really need to get that sound working... I really appreciate any help you guys can give. I wrote up a ticket with Reallusion, but of course, no reply.
