BiggsTrek
BiggsTrek
Posted Last Year
Last Active: 5 Months Ago
Visits: 12.3K
animagic (10/4/2024) Sorry about the lack of response from RL. Legacy particles are still useful, so I added my vote.Thanks animagic, appreciate the support!
 https://marketplace.reallusion.com/iclone/author/biggstrek
Posted Last Year
Posts: 15.8K,
Visits: 31.4K
BiggsTrek
BiggsTrek
Posted Last Year
Visits: 12.3K
Hello All, I wonder if I could get a little help. I raised a Support Ticket last year for some Legacy Particle Emitter bugs in iClone. The Ticket was closed but the bugs were not fixed (Reallusion told me the fixes were "lost" and I should raise the bugs in the Feedback Tracker instead.) So I raised the issue in Feedback Tracker earlier this year, where it has seen no "love". I won't go into the details, but suffice to say the bugs affect me making Particle Emitters in iClone 8 and I really think they should be fixed. So, could I ask you to go review my Feedback Entry and give it a Vote Up, if you can. Issue 11261 https://www.reallusion.com/FeedBackTracker/Issue/Three-3-Problems-with-Legacy-Particle-Emitters-and-the-Life-parameters-Min-and-Max(The issues are all related to the LIFE of particles, especially when setting Max to under 1 second (e.g.: 0.500) where they no longer generate at all! Ever since they changed LIFE from Frames to Seconds, it's been broken. The change itself makes sense, as Frames are variable in our Projects now, but it needs to be fixed so it works properly.)Thanks in advance!
BiggsTrek
BiggsTrek
Posted Last Year
Visits: 12.3K
Just when you thought, "damn this guy must have run out of stupid ideas", well, guess again! I'm full of stupid ideas!! Today I released a pack of Dragon Breath Particle Emitter Props! Dragon Breath - Themed Emitter Pack From the description:To all the Dungeons and Dragons fans out there, I've created these five Legacy Particle Emitter Props just for you!
They are based on the five Primary Chromatic Dragon types (yes, there are others, but these are the basis for most of them.) Followers of Tiamat!
Featuring five all new DRAGON BREATH Particle Emitters!
- Black Dragon Breath (ACID Stream)
- Blue Dragon Breath (LIGHTNING Line)
- Green Dragon Breath (POISONOUS GAS Cloud)
- Red Dragon Breath (FIRE/HEAT Cone)
- White Dragon Breath (ICE/FROST/COLD Cone)
As usual, each prop consists of a dummy where the emitters are attached. The dummy contains an AML script, so to activate the effect, right click the dummy, select PERFORM then either turn the effect ON! or OFF! SIMPLE!
BiggsTrek
BiggsTrek
Posted Last Year
Visits: 12.3K
I'm back again, this time with my latest SIX PACK of Legacy Particle Emitter Props: Particle Emitter Six Pack (O) https://marketplace.reallusion.com/particle-emitter-six-pack-o This Pack contains the following Legacy Particle Emitter Props (previously released individually): - Laser Pulse Emitter
- Disintegrator Beam Emitter
- Heat Ray Emitter
- Fog Wall Emitter
- Ghost (V2) Emitter
- TransMatter (V6) Emitter
Most, if not all, come with handy built in AML scripts. Simply right click, Perform then select the desired action to activate/deactivate the effects (see individual listings for more details.)
(This one above is the latest - Laser Pulse Emitter, inspired by Forbidden Planet. Available individually if you prefer.)
BiggsTrek
BiggsTrek
Posted Last Year
Visits: 12.3K
yogdyr (8/3/2024) The emote emitter was awesome. Thanks for your work.Thanks, glad you like it! -------------------------- BTW everyone, I've done a little re-pricing of my Packs. Most of my older ones have been reduced (permanently) to match the philosophy of " Buy a PACK of SIX for the price of FIVE!" (or whatever the number in the Pack is - one is FREE!)Enjoy!
yogdyr
Visits: 2.3K
BiggsTrek
BiggsTrek
Posted Last Year
Visits: 12.3K
Hey all, I've got another one for you, a HEAT RAY!"The Martians are coming, the Martians are coming!!" (Also works well as a flamethrower...)https://marketplace.reallusion.com/heat-ray-emitter Product description
The Martians Are Coming!!! The Martians Are Coming!!! Or ... Get those Giant Ants with the Flamethrower! Or maybe.... Cast your Ultimate Flaming Hands Spell at the enemy!! So yeah, this Legacy Particle Emitter Prop has multiple possible uses. Initially I designed it based on the 1953 War Of The Worlds movie special effect "Heat Ray", but saw it would also work as a good Flame Thrower effect, and definitely make a good magical spell effect as well. Heck, why not use it as the Fiery Breath of Smaug the Dragon! As usual, all emitters are attached to a dummy prop. The effect can be activated and deactivated by the convenient AML script attached to the dummy prop. Simply right click "Perform" then select either "Heat Ray - ON" or Heat Ray - OFF" https://marketplace.reallusion.com/heat-ray-emitter
BiggsTrek
BiggsTrek
Posted Last Year
Visits: 12.3K
Hey again all, This came in a fevered dream. Well, maybe a nightmare. Or just a weird fantasy. Whatever it was, here it is! My latest Particle Emitter Pack! EMOTE EMITTER PACKBased on those pesky Facebook emoticon thingamajigs, I've made up Seven new Particle Emitter Props, each with three functions for emitting their respective Emotes: LIKE LOVE SAD CARE WOW HAHA ANGRYYou can send a Single emote, or a Stream or an Area with just a click or three of a button! Here's some pictures to whet your appetite:
Hope you enjoy!
https://marketplace.reallusion.com/emoticon-emitter-pack
Cheers!
BiggsTrek
BiggsTrek
Posted Last Year
Visits: 12.3K
And now for something FREE! Yay!!! TransMatter Emitter v7 (yes, it's a freebie...)It got kind of Matrixy (not a word.)  https://marketplace.reallusion.com/transmatter-v7-emitterEnjoy!
