Unable to uninstall trial iClone5 Pro to install full version
Posted By StreamingTrout 10 Years Ago
StreamingTrout
StreamingTrout
Posted 10 Years Ago
Senior Member (406 reputation)Senior Member (406 reputation)Senior Member (406 reputation)Senior Member (406 reputation)Senior Member (406 reputation)Senior Member (406 reputation)Senior Member (406 reputation)Senior Member (406 reputation)Senior Member (406 reputation)
Posts: 7, Visits: 133
During an installation of iClone 5 Pro, the setup program complained that another version (trial) was installed - which is true. i can't use the Win7 system uninstallation because iClone5 does not show up on the list. Direct deletion did not work (though I may not have found all the files to delete). I did not (yet) edit the registry, though I did find Reallusion entries in it. I figured I'd ask for feedback here before I went that route.
Thank you for any help you can provide.
Posted 10 Years Ago
Last Active: 11 hours ago
Posts: 5.7K, Visits: 26.4K
You should have been able to remove the trial version under All Programs>Reallusion>Uninstall. If you have just tried to delete a few folders then the details are still stored in the registry.
Running a registry cleaner may help, but you could also end up with some messed-up folders on your system.
Take a look in C:\Program Files (x86)\Reallusion and remove anything to do with iClone.
Also look in C:\Users\All Users for anything to do with Reallusion as well as in C:\Users\Public\Documents.
After that your reg cleaner should be run. If you don't have a reg cleaner on your system then you might want to have a look for ccleaner - it's pretty good.
Posted 10 Years Ago
Distinguished Member (116.4K reputation)Distinguished Member (116.4K reputation)Distinguished Member (116.4K reputation)Distinguished Member (116.4K reputation)Distinguished Member (116.4K reputation)Distinguished Member (116.4K reputation)Distinguished Member (116.4K reputation)Distinguished Member (116.4K reputation)Distinguished Member (116.4K reputation)
Last Active: Today @ 2:36 AM
Posts: 22.7K, Visits: 35.7K
StreamingTrout (6/28/2014)
Hi..
Sorry to hear you are experiencing problems.
If you contact us at Support using the link below, we will give you a special registry cleaner to remove your iClone5 trial registry data. This will enable you to install the full version.
http://www.reallusion.com/CustomerSupport/User/QForm.aspx
