Question: DAZ to MAX (biped) possible?
Posted By T.Kick 12 Years Ago
T.Kick
T.Kick
Posted 12 Years Ago
Junior Member (246 reputation)Junior Member (246 reputation)Junior Member (246 reputation)Junior Member (246 reputation)Junior Member (246 reputation)Junior Member (246 reputation)Junior Member (246 reputation)Junior Member (246 reputation)Junior Member (246 reputation)
Last Active: 12 Years Ago
Posts: 8, Visits: 14
Hi,
New to iClone and was wondering;
Is Iclone/ 3DXchange all about motion(data) or is it also possible to export/ transform a character from DAZ(bones)-scene to a MAX(biped)-scene?
Thanks in advance.
T.Kick
T.Kick
Posted 12 Years Ago
My main objective would be to get a DAZ character into MAX.
But I don't want to work with Bones. I want a biped-based character.
As there are few tools to handle this job, I wondered if 3DXchange could do the job?
The tutorials I've seen so far do some vague(to me) biped to bones, back to biped trick.
But I don't see an actual new scene or biped-system created, just some transference of animation-data?
Hope this clarifies some.
Cricky
Cricky
Posted 12 Years Ago
Skype ID= learn.iclone
Skype ID= learn.iclone (14.0K reputation)Skype ID= learn.iclone (14.0K reputation)Skype ID= learn.iclone (14.0K reputation)Skype ID= learn.iclone (14.0K reputation)Skype ID= learn.iclone (14.0K reputation)Skype ID= learn.iclone (14.0K reputation)Skype ID= learn.iclone (14.0K reputation)Skype ID= learn.iclone (14.0K reputation)Skype ID= learn.iclone (14.0K reputation)
Posts: 2.8K, Visits: 13.8K
T.Kick (11/18/2013)
If you want to use anything as a Biped Rig defined by Max, you will have to define what bone or dummy used by the imported mesh is assigned to match the biped structure inside Max.
Regardless of the method used, whether it be (1) from DAZ directly -or- (2) Daz -> iClone -> Max, you still have to assign appropriate nodes so the software knows what bone (or dummy) is mapped to what.
Max has Node transfer/assignment tools, and there are tutorials out to show this being done.
This one (Shown below) can go either way as explained above. I don't understand why you would want to send it to a Biped rig, and no explanation is needed, you want it; simple enough.
If you want it you will need to research reassignment of nodes from one bone or dummy set to a biped rig inside MAX. No reassignment was done to the one shown below. It uses the original bone set assigned to animate inside Max.
SKYPE ID: rc.650
T.Kick
T.Kick
Posted 12 Years Ago
Maybe that's exactly what I'm looking for, an automated Node transfer/assignment tool ...
(and it didn't really work for me in MAX, maybe I should try again ..)
As there seem to be tools. in 3DXchange, to transfer data from bones-systems to max biped, I thought ... well ... hoped that maybe an export-function was also available.
I mean ... the program goes THAT far, but not this last little 'leap' ....
And as my knowledge AND time is limited ...
T.Kick
T.Kick
Posted 12 Years Ago
But also ....
If it's possible, within 3DXchange, with a little re-assigning, and good result, I'd sure like to give it a try.
Is there any info on that available?
Sen
Sen
Posted 12 Years Ago
Distinguished Member (8.6K reputation)Distinguished Member (8.6K reputation)Distinguished Member (8.6K reputation)Distinguished Member (8.6K reputation)Distinguished Member (8.6K reputation)Distinguished Member (8.6K reputation)Distinguished Member (8.6K reputation)Distinguished Member (8.6K reputation)Distinguished Member (8.6K reputation)
Last Active: 6 Months Ago
Posts: 2.8K, Visits: 28.5K
Hi ,
DAZ (fbx export) > 3dsmax (fbx import) + a maxscript (like GameToBiped or Bippy ) . No need 3dx5 here ;) . You can also write your own script :) .
CGTRADER
T.Kick
T.Kick
Posted 12 Years Ago
hmm ... will have a look-see ... cheers.
btw. I CANNOT write my own script .... ;-)
T.Kick
T.Kick
Posted 12 Years Ago
character on biped is< I think, the reverse of what I'm looking for?
GameToBiped and Bippy both keep failing: Error
Using MAX 2012
T.Kick
T.Kick
Posted 12 Years Ago
correct, that's 'all' ...
T.Kick
T.Kick
Posted 12 Years Ago
Any help highly appreciated
