AverageJoe
AverageJoe
Posted 12 Years Ago
Last Active: 10 Months Ago
Posts: 2.4K,
Visits: 10.1K
I had avoided the motion library clip, because it's so very generic. I like the customization in the walk cycle. But the tip of breaking the clip and just pulling the specific keyframes is a great idea. Thanx vidi...
vidi
Posts: 10.8K,
Visits: 40.2K
You can Use the Motion Libary http://www.reallusion.com/ContentStore/promo/CTA-Big_Combo/default_Motion.aspxOr you can ungrouped you puppet Clip on the timline . So you get access to the keys Extract the cycle , remove the unnecessary keys and copied the first key and set after the last Key. Keep it simple, because you make a game not a animation Jumping Ani eg. can only 2-3 Frame be, because the transform is with "programming"
kurzal
kurzal
Posted 12 Years Ago
Visits: 10.4K
-------- Igor
AverageJoe
AverageJoe
Posted 12 Years Ago
Posts: 2.4K,
Visits: 10.1K
vidi (9/26/2013) I create the animation clips and export it in separate folder as Idle ,Walk ... ect
Also e.g. I make the eyes seperatly, attach it on the Character with Imagespoint so I can make a randomly blink . Also then I use Container
In CTA the pre animations like walk, run is a cycle. Most I export it as 12 frame Animation , to have not so many frames. It is not necessary for 2D Games .If the Animation had 12 Frames In the Animation edior in Construct I set Speed 12 then.But when I apply a walk cycle it keeps going until I manually stop it, using the puppeteering panel, although not actively puppeteering. You know, where you can modify the aspects of the walk cycle... Arm sway, stride length, bounce, etc... It records the action when you hit the space bar and keeps going until you hit the space bar again. Is there any easy way, or a tip to do it this way (again for a custom walk), but only pull out the appropriate frames that make up 1 single cycle? Or do you apply the generic walk cycle from the actions in the content manager? It's important because if you don't get the correct frames, when you attempt to build the sprite animation, it will not look right. That's the issue I have, is in knowing which frames make 1 and only 1 complete cycle?
vidi
Posts: 10.8K,
Visits: 40.2K
I create the animation clips and export it in separate folder as Idle ,Walk ... ect Also e.g. I make the eyes seperatly, attach it on the Character with Imagespoint so I can make a randomly blink . Also then I use Container In CTA the pre animations like walk, run is a cycle. Most I export it as 12 frame Animation , to have not so many frames. It is not necessary for 2D Games .If the Animation had 12 Frames In the Animation edior in Construct I set Speed 12 then.
AverageJoe
AverageJoe
Posted 12 Years Ago
Posts: 2.4K,
Visits: 10.1K
vidi (9/25/2013) Export with solid Color Background should work . I exported every my animated Characters as png sequence for 2D game assets and BG is transparency.Hey vidi, aren't you the one that pointed out Construct 2? If so, thanx... I really really enjoy working with that engine. Have any tips on how you export your characters for it? Meaning, for example, do you create a bunch of animations then export them all out or do you create a dedicated walk animation, a dedicated jumping animation, etc? I've tried doing just a walk sequence but have some issues on getting just one cycle exported out. Do you have any tips for that? Regardless, thanx for the info about C2 again, it's really is put together very well.
vidi
Posts: 10.8K,
Visits: 40.2K
kris.kind
kris.kind
Posted 12 Years Ago
Last Active: 12 Years Ago
Visits: 7
Thanks, it actually does work. I imported my render to gimp and there is a transparent backgrounf behind the face. Have to manage to import it to premiere Pro CS6... Thank you!!!
planetstardragon
planetstardragon
Posted 12 Years Ago
Last Active: 4 Months Ago
Posts: 11.5K,
Visits: 46.0K
Hi kris.kind, Welcome to the forum! try making your png 32 bit - then it will export with transparency settings ;) Cheers!
kris.kind
kris.kind
Posted 12 Years Ago
Visits: 7
Hi, i used search function and google and can't work it out. I try to animate a face and use it on a real video in premiere CS6. Therefor I need a transparent background. In the project settings of CTA Pro it's only possible to use a color. I don't want to use a chroma key in Premiere. Any possibility to export that animated face with alpha channel?
Of course the face has transparent background but the projects background is exportet and can't be removed.
