Making Characters Move to a Beat
Posted By jarronn 12 Years Ago
planetstardragon
planetstardragon
Posted 12 Years Ago
Distinguished Member (24.1K reputation)Distinguished Member (24.1K reputation)Distinguished Member (24.1K reputation)Distinguished Member (24.1K reputation)Distinguished Member (24.1K reputation)Distinguished Member (24.1K reputation)Distinguished Member (24.1K reputation)Distinguished Member (24.1K reputation)Distinguished Member (24.1K reputation)
Last Active: 4 Months Ago
Posts: 11.5K, Visits: 46.0K
for cta or iclone, i usually do the beat matching in the video editor, sony moviemaker has a nice time stretch feature to make it easy. I never use long unedited sequences, so I usually will go 5 seconds most then edit. you can do it in cta or iclone too by time stretching the motions, but it's easier in the video editor, plus if you have a heavy scene ( namely in iclone ) it will tend to make your music and visual drift a bit making it even harder to beat match. I'll just get it relatively close in iclone / cta then fine tune it in editor.
basically I approach it more like a DJ than a techie
"To define Tao is to defile it" - Lao Tzu
jarronn
jarronn
Posted 12 Years Ago
Group: Banned Members
Last Active: 10 Years Ago
Posts: 160, Visits: 499
jlittle (8/23/2013)
There are no "Auto Dancing" functions in CTA. You must sync your characters manually.
You can use the pre-canned dance moves and stretch/compress them to speed them up or slow them down to sync with the music.
Using an actors voice clip to show the waveform (as mentioned above) can help you see various "beats" in the song as a guide.
Also consider that most music will tend to be at a specific beats per minute (bpm) and if you can figure that out then you can get an approx number of frames per beat which can help you get the characters movement close to the beat.
Ex: a song at 70 beats/min = 1.6667 secs/beat = 35 frames per beat (@30fps)
Jeff
Okay, in a situation like this I assume I can stretch or compress the time of the 'canned' dancing moves and get it close to synchronized for a short time before they start to go out of sync again.
At that point can I pause the video re-sync the time of the canned dance move and restart so that the characters are re-synced to the beat from that point and then do it each and every time they start to dance off of the beat thus manually correcting the canned dance moves whenever I may need to?
__________________________________________________________________________________________
Many of your answers can be found by reading the product manual.
The online manual and the online help are NOT the same thing
jlittle
jlittle
Posted 12 Years Ago
Posts: 1.9K, Visits: 17.3K
jarronn (8/23/2013)
If you are doing the time stretch/compression in CTA then you have to do it motion clip by clip.
You can not pause the export and adjust things.
Each motion clip is short enough that you should be able to adjust each one as needed to keep it in sync.
Jeff
jlittle
jlittle
Posted 12 Years Ago
jarronn (8/23/2013)
FROM NOW ON I'll remember to ALWAYS put CTA PRO in the title of a topic thread so this confusion will not happen again
I take full responsibility for not doing that and I don't intend to have it happen again
Sorry folks for the misunderstanding ;)
UPDATE:
Sheesh! I didn't even put CTA Pro in the opening post!!!!
That was very careless of me. I assumed to much about this particular forum
It's not that you made a mistake but some us on the forum monitor more than just one area: i.e. iClone, CTA, CT7, etc. and sometimes when the we click on the links emailed to us we don't always notice which forum/product it is for. Most will assume it is for the one they use the most ... thus leading to confusion.
It doesn't happen that often so not to worry.
Jeff
wendyluvscatz
wendyluvscatz
Posted 12 Years Ago
Senior Forum Member
Senior Forum Member (12.2K reputation)Senior Forum Member (12.2K reputation)Senior Forum Member (12.2K reputation)Senior Forum Member (12.2K reputation)Senior Forum Member (12.2K reputation)Senior Forum Member (12.2K reputation)Senior Forum Member (12.2K reputation)Senior Forum Member (12.2K reputation)Senior Forum Member (12.2K reputation)
Posts: 2.5K, Visits: 19.4K
I saw in posts since last visit but saw it was crazytalk forum too.
Just looked out of curiosity as I do and noticed iClone answers so subtly hinted to the silly blighters who posted! :w00t:
bunch of Wallys!! :P
the post edit idea applies though, I myself do it outside iClone, dunno enough about crazytalk to suggest much
