Problem creating Crazytalk Animator props with Flash
Posted By webdefender 12 Years Ago
webdefender
webdefender
Posted 12 Years Ago
Veteran Member (970 reputation)Veteran Member (970 reputation)Veteran Member (970 reputation)Veteran Member (970 reputation)Veteran Member (970 reputation)Veteran Member (970 reputation)Veteran Member (970 reputation)Veteran Member (970 reputation)Veteran Member (970 reputation)
Posts: 28, Visits: 505
I am having a problem importing Flash files to use as props. I have an object that appears gradually over the course of the animation. My problem is that I want the animation to pause on the last frame. It doesn't look like there is a straight forward was to accomplish this. So my solution was to create 2 swfs, one with the animation and one with only the last frame. The problem is the default center for each is different so when I do a sprite replacement, the replacement sprite completely changes position. Any ideas?
