Thanks Pat59 and Armstrong
The product is already released and available in our Animations4iClone Theme store.
In terms of controls, you are in absolute control to shape it anyway you want. The actual response of the mesh is pretty smooth. The prop is scaled to perfectly fit the default iClone Terrain size and the resolution of the textures is very high providing a really good finish at that size.
You can also rescale the terrain smaller and make an extremely detailed base for close shots.
Once you have shaped the terrain Prop to your liking, you can also convert it to a terrain (add to terrain) and all your changes will be maintained you can save different terrains for future use.
The Handles that are used to shape the terrain operate on 3 layers (Grass, Dirt, Rock) and so you can move each layer together or independently and create for instance, dirt in the deep sections and grass in the ground section etc... Since each layer has its own texture channels, you can even play a Video on mesh to simulate Moving Lava etc..
But the most impressive part is that you can animate terrain deformation on the timeline and create special effect that are really Cool.
For instance, I look forward to what txon will do with this kind of capabilities
Cheers!
Come and visit my store by clicking on the banner below.
11 Years Ago by
Bigboss
