Custom Shirt Doesnt Look Right
Posted By EvilGenius 11 Years Ago
EvilGenius
EvilGenius
Posted 11 Years Ago
Distinguished Member (4.9K reputation)Distinguished Member (4.9K reputation)Distinguished Member (4.9K reputation)Distinguished Member (4.9K reputation)Distinguished Member (4.9K reputation)Distinguished Member (4.9K reputation)Distinguished Member (4.9K reputation)Distinguished Member (4.9K reputation)Distinguished Member (4.9K reputation)
Last Active: 8 days ago
Posts: 255, Visits: 1.1K
I added a custom shirt and cannot get it to look right.
Then I decided to replace the upper arm sprite with the entire shirt and mask out everything except the sleeve. That left me with this problem.
The bottom portion of the arm is gone and now the top of the sleeve separates from the shirt and doesn't look right.
Does anyone have any suggestions on how I can take clothes I find online and make them look right?
prabhatM
prabhatM
Posted 11 Years Ago
Distinguished Member (6.4K reputation)Distinguished Member (6.4K reputation)Distinguished Member (6.4K reputation)Distinguished Member (6.4K reputation)Distinguished Member (6.4K reputation)Distinguished Member (6.4K reputation)Distinguished Member (6.4K reputation)Distinguished Member (6.4K reputation)Distinguished Member (6.4K reputation)
Posts: 1.8K, Visits: 8.1K
EvilGenius (5/23/2013)
I have not worked with CTA. But I think the SLEEVE should be part of the ARM, not the custom shirt. Then the sleeve will move along with the arm.
11 Years Ago by prabhatM
jlittle
jlittle
Posted 11 Years Ago
Posts: 1.9K, Visits: 17.1K
Yes, you have to break the shirt up for each body part and then replace/add those sprites.
It is similar to photo fitting a body if you are using an image.
Jeff
11 Years Ago by jlittle
EvilGenius
EvilGenius
Posted 11 Years Ago
Very good suggestion Jeff thank you. I was completely skipping actor creation and had hoped to accomplish what I wanted through the Character Composer.
I guess there is no getting around it, I have to go through the actor creator.
Thanks again.
AverageJoe
AverageJoe
Posted 11 Years Ago
Distinguished Member (10.7K reputation)Distinguished Member (10.7K reputation)Distinguished Member (10.7K reputation)Distinguished Member (10.7K reputation)Distinguished Member (10.7K reputation)Distinguished Member (10.7K reputation)Distinguished Member (10.7K reputation)Distinguished Member (10.7K reputation)Distinguished Member (10.7K reputation)
Posts: 2.4K, Visits: 10.1K
Thanks again.
You do not have to go through the actor creator. You can break the shirt up externally into three pieces and import them in the character composer. But you'll also need to add the upper arm to the sleeves externally as well, then just import a new 2 new upper arms (your sleeves) as well as the torso.
EvilGenius
EvilGenius
Posted 11 Years Ago
I have been going absolutely crazy trying to get my custom shirt to look right but have had zero luck. I just cannot get it to look how it is supposed to. Can someone give me some pointers? I have watched just about every tutorial video and have tried my best to properly mask the arms and still cannot get it right. Here is what I am working with.
jlittle
jlittle
Posted 11 Years Ago
EvilGenius (7/18/2013)
What is the problem?
Do you have the shirt broken up as shown below?
Jeff
