Pop Convertor won't export
Posted By tuttut_nut 13 Years Ago
Posted 13 Years Ago
Posts: 23.1K, Visits: 36.6K
popVideo Converter 2 will use the video codecs you have installed on your computer. So if you have recently moved from Windows 7 to Windows 8 all your video codecs you used to have are no longer there, which is likely why you are now encountering problems.
You just need to ensure you have suitable set of codecs installed in Windows 8 and you should have no problems. I'm using Windows 8 without any issues with popVideo Converter.
I will say it is almost essential you also have a good quality video converter such as the free Format Factory because there will always be some video formats not supported by PC2 that will need converting.
For me I use DivX or Xvid for AVI, WMV works almost perfectly straight out of the box, and if you want to use MOV format then you will need to install the latest QuickTime software.
I hope this helps.
tuttut_nut
tuttut_nut
Posted 13 Years Ago
Last Active: 13 Years Ago
Posts: 52, Visits: 1.0K
I have had the software as a trial a few years back and it worked fine, so I bought it now as I need it for the work i do. Struggling to produce anything with it. It takes forever at the "encoding video stream" stage and eventually I just give up and try the more reliable Sony Vegas Pro. Very frustrating having software I am unable to use that would make my life much easier.
I have noticed (now) that it only seems to go to Windows 7 and I have Windows 8 installed. Could this be the problem? I have tried AVI and MOV formats but whatever I do. It doesn't want to know. I have a Radeon Graphics card and it is set to high performance, so I wouldn't have thought there would be a problem.
