Hi Rampa,
I have a further update for you.
Currently the plan is to improve this particular feature in the next version of 3DXchange.
However for now though, we suggest that you can use the LUA file attached, and then replace the three files referenced below with your own walk motions. This will allow you to add custom walk motions by using the right click method.
Walk_Forward_Start.iMotion
Walk_Forward.iMotion
Walk_Forward_End.iMotion
Hope this helps. :)
