How to change fps?
Posted By BC.Rice 14 Years Ago
limegreen
limegreen
Posted 10 Years Ago
New Member (3 reputation)New Member (3 reputation)New Member (3 reputation)New Member (3 reputation)New Member (3 reputation)New Member (3 reputation)New Member (3 reputation)New Member (3 reputation)New Member (3 reputation)
Last Active: 10 Years Ago
Posts: 1, Visits: 3
How do you time a 25fps piece inside a 30fps limited package? You need to be able to adjust the default for a given project. For example - if you are creating elements that are going into a broadcast show, and its at 25fps, then you animate at 30 fps, then export the file at 25 fps, it does not integrate with other broadcast footage at 25fps, as its been altered...
jlittle
jlittle
Posted 14 Years Ago
Posts: 1.9K, Visits: 17.3K
You change the frame rate on the export tab when you export.
Note that there are different frame rates for each of the export tabs (i.e. Video, Image, Web)
Jeff
BC.Rice
BC.Rice
Posted 14 Years Ago
Veteran Member (607 reputation)Veteran Member (607 reputation)Veteran Member (607 reputation)Veteran Member (607 reputation)Veteran Member (607 reputation)Veteran Member (607 reputation)Veteran Member (607 reputation)Veteran Member (607 reputation)Veteran Member (607 reputation)
Last Active: 14 Years Ago
Posts: 3, Visits: 6
Hello --
I'm trying to figure out how to change my animations to 24fps and 12fps. Looks like the default is just 30fps.
Thanks!
