Expanding and Organizing Motion Puppet
Posted By rcsinger29 13 Years Ago
rcsinger29
rcsinger29
Posted 13 Years Ago
Distinguished Member (7.3K reputation)Distinguished Member (7.3K reputation)Distinguished Member (7.3K reputation)Distinguished Member (7.3K reputation)Distinguished Member (7.3K reputation)Distinguished Member (7.3K reputation)Distinguished Member (7.3K reputation)Distinguished Member (7.3K reputation)Distinguished Member (7.3K reputation)
Posts: 782, Visits: 3.2K
I have spent a good deal of time this week trying to get some of my purchased motions into motion puppet so I may use this powerful tool for quick and realistic animation and I ran into my share of problems and crashes during the process.
For those of you who don't already know how to do this, I decided to streamline the info found in multiple places on the forum into one process to assist in achieving both a robust and an organized Puppet Tool.
Special thanks to Sen for his past tut's and to Rampa for taking a moment to tinker with his to provide this info.
The path where the puppet motions are located is:
C:\Documents\Reallusion\Template\iClone 5 Template\iClone Template\Preset\
Depending on your OS, it may be "My Documents" or "Public Documents"
The Base Motion folder is the only one you will have in this Location by default along with a file named "OrderList.ini" -- Ignore this file, you do not have to edit, copy, paste, or evemn look at it.
Inside the Base Motion folder, you will find 4 folders; Idle, Mood, Move, and Talk,
Inside each of these you will find the pupper motions and 3 BMP files. These BMP's are the icons located above the motions in the puppet panel inside iClone.
To Add a custom motion folder or "category", Create a new folder in the preset folder named anything you like. Inside this NEW folder, create Folders for your desired motions.
*IMPORTANT* You must have the BMP files located in each folder you add to your new motion category and they must be named as follows:
If these are not present or are not named with the same as the folder they are in, the puppet will CRASH iClone.
Its a good idea at this point to Launch Iclone, add an actor, and bring up the puppet to make sure your new category is there. It should be located in the drop down menu along with the default "Base motion" category.
If all is well, move on, if not, review and retry.
***iClone loads information for the puppet at program launch so it is important that iClone is closed while you are editing the folder(s) and that you launch the program for each test, if your iClone is idle and you make changes, you will not see these changes until you close and relaunch iClone***
To get your motions into your new category, navigate to their location using your explorer
C:\\Documents\Reallusion\Template\iClone 5 Template\iClone Template\Motion\
OR
C:\\Documents\Reallusion\Custom\iClone 5 Custom\Motion
Copy your desired motion(s) and paste them into your new folder(s)
*IMPORTANT* For the puppet to interperet the motion, it must have a configuration (.INI) file.
Simply open the "Base Motion" folder and select any of the existing INI files in this directory and copy, then paste it inside the folder with your new motion, then name the file the same as the motion file.
These INI files are identical to one another so it does not matter which one you pick.
At this point, you if you have followed these steps, you will have a new category and new motion(s) to use in your puppet.
If the puppet crashes iClone, review the folder(s) and names to make sure the names, capitalizations are correct and the BMP's are present and the BMP's are there.
You may add as many category folders as you like and add motions to any of them including the base motion folder.
Keep in mind that the more motions included in a single category effects the time it takes for the puppet to load that category so keep each new folder as small as you can. Once you get over 50 in one category, you start to notice (depending on your system this number may be higher or lower).
Hopefully this will help you save time and a lot of keyframing to get that perfect motion in your next animation.
Vet's, if there is anything I left out or need to add, chime in and I'll edit my post.
I created and keep a template folder in the base motion folder to quickly add new motions
"Folder Template" including Idle, Mood, Move, Talk and each of those containing only the 3 required bumps and this folder just sits, If/When I need a new category, I simply copy and paste this folder in the same directory (creating "Folder Template - Copy", then edit this copy to create my new motion category)
Threaded View
Threaded View
Forum Post Expanding and Organizing Motion Puppet By rcsinger29 ( 13 Years Ago )
Forum Post RC, great minds think alike....and so do ours. It seems I did a... By martok2112 ( 13 Years Ago )
Forum Post Capitalization crashed mine. Walk Backward loop.iMotion Walk... By rcsinger29 ( 13 Years Ago )
Forum Post Ok....so capitalization IS indeed important. Alright, we've now... By martok2112 ( 13 Years Ago )
Forum Post Mine actually crashed. I added just a few motions in several... By rcsinger29 ( 13 Years Ago )
Forum Post Sample \ By rcsinger29 ( 13 Years Ago )
Forum Post I tried this out and it seems to work. But: [quote]These INI files... By Neuling ( 12 Years Ago )
Forum Post Great summary. Now we just need some tool that creates a checked list... By RobertoColombo ( 12 Years Ago )
Forum Post Hi Swoooop It's inexact to say :" turn on macro recorder and ok ".... By Sen ( 12 Years Ago )
Forum Post thank :P a "pun" , ah ! yes I find a good translation :D . I... By Sen ( 12 Years Ago )
Forum Post Actually, the idea to have a simple tool that help to add dozens of... By RobertoColombo ( 12 Years Ago )
Forum Post Great stuff thx allot By Asamadi ( 12 Years Ago )
Forum Post Thanks everyone for this thread! Was playing with Motion Puppet... By msjaebea ( 12 Years Ago )
Forum Post I am going to add a bit of info here from my findings. Only iMotions... By msjaebea ( 12 Years Ago )
Forum Post AWESOME JOB! thank you. I was losing my mind. Note you don't need... By bfirst786+Realillusion ( 11 Years Ago )
Forum Post Hi RL community, I come back to this old topic because I experienced... By RobertoColombo ( 10 Years Ago )
Forum Post I found the solution to this not working in iC6! :) Just put "Base... By Rampa ( 9 Years Ago )
Forum Post Great Rampa!!! Thanks a lot for finding the solution. I wonder how... By RobertoColombo ( 9 Years Ago )
Forum Post Of course I tried everything else I could think of first! ;) Spent... By Rampa ( 9 Years Ago )
