iClone LUA Script API
Posted By KaiD 14 Years Ago
Pankratz
Pankratz
Posted 10 Years Ago
Veteran Member (506 reputation)Veteran Member (506 reputation)Veteran Member (506 reputation)Veteran Member (506 reputation)Veteran Member (506 reputation)Veteran Member (506 reputation)Veteran Member (506 reputation)Veteran Member (506 reputation)Veteran Member (506 reputation)
Posts: 10, Visits: 119
You can vote for access on RL's Feedback Tracker here.
I'd definitely find it useful to create custom controls such as iclone's light tool.
CRANK
CRANK
Posted 10 Years Ago
Veteran Member (862 reputation)Veteran Member (862 reputation)Veteran Member (862 reputation)Veteran Member (862 reputation)Veteran Member (862 reputation)Veteran Member (862 reputation)Veteran Member (862 reputation)Veteran Member (862 reputation)Veteran Member (862 reputation)
Posts: 47, Visits: 8.7K
https://forum.reallusion.com/uploads/images/9957a33f-85ed-49d0-bf75-c5cf.png
lua
CRANK
CRANK
Posted 10 Years Ago
lua
CRANK
CRANK
Posted 10 Years Ago
Certainly on props.The perform commands are Lua's
They are easy to create using the time line.
Very simple lua
load  a box move the time on say ten squares then move the box.
If you now press play the box will move.
To repeat this action-Enter the time line select your box-transform.
On the line that says collect clip-
You will see two white dots.
Drag the cursor back from the second one to the beginning whilst holding the left mouse button.
Right click on the highlighted rectangle you've created and select add to perform name it whatever 'move box,
You have created a lua.
Now remove animation from box-Right click and select perform The Option 'Move box will appear.
Hope this was useful.
Cheers the Crank
PS you can create motion / Performs for characters in a similar way.
R2 Studio
R2 Studio
Posted 10 Years Ago
Posts: 59, Visits: 377
I mean, is it possible to use them on characters and props... are there scene controls, too?
R2 Studio
R2 Studio
Posted 10 Years Ago
I'd like to use it for both, if possible.
CRANK
CRANK
Posted 10 Years Ago
Hi what are you looking to add a Lua to? Prop or Character?
com556
com556
Posted 10 Years Ago
Last Active: 10 Years Ago
Posts: 1, Visits: 14
Hi, All
Where can I find a guide to programming Lua script iClone?
R2 Studio
R2 Studio
Posted 10 Years Ago
It has been four years since you said you were working on it... any updates yet?
Posted 11 Years Ago
Last Active: 5 days ago
Posts: 8.2K, Visits: 62.6K
You might be interested in using the AML editor, sense AML still works in iC6. Grab it here.
http://developer.reallusion.com/amleditor.aspx
Or check out some documentation here.
http://www.reallusion.com/iclone/help/amleditor/
You'll need to open the resultant AML's you generate, and take the "$" signs out of the motion file path names. The "$" sign was a wild card. When you add your own files, they will be absolute paths, so you won't need the wild card.
The existing personas are in AML, and can be opened directly in this program. They only get saved as Lua when exported from iClone.
