Is it possible to copy and paste objects from a project into another?
Posted By torresroberto 13 Years Ago
torresroberto
torresroberto
Posted 13 Years Ago
Senior Member (348 reputation)Senior Member (348 reputation)Senior Member (348 reputation)Senior Member (348 reputation)Senior Member (348 reputation)Senior Member (348 reputation)Senior Member (348 reputation)Senior Member (348 reputation)Senior Member (348 reputation)
Last Active: 13 Years Ago
Posts: 9, Visits: 164
Hi, I have several projects that I want to copy/paste or import into a single project, is this possible? :hehe:
planetstardragon
planetstardragon
Posted 13 Years Ago
Distinguished Member (24.1K reputation)Distinguished Member (24.1K reputation)Distinguished Member (24.1K reputation)Distinguished Member (24.1K reputation)Distinguished Member (24.1K reputation)Distinguished Member (24.1K reputation)Distinguished Member (24.1K reputation)Distinguished Member (24.1K reputation)Distinguished Member (24.1K reputation)
Last Active: 4 Months Ago
Posts: 11.5K, Visits: 46.0K
nah, not directly anyway....
a way to do it is to create a folder in your prop tab that will have all the parts you want in one scene.
then open your scenes and individually save the props you want to that folder. When you call them into the file you want, the new saved file should save it's location so it will fall into place if you wanted to keep everything where it was at. Otherwise, center your prop before saving so the coordinates will start from center.
Good luck!
"To define Tao is to defile it" - Lao Tzu
torresroberto
torresroberto
Posted 13 Years Ago
What if I did create a complex animation using the Timeline and other tools, would these steps help me not to do all the work I did?
wendyluvscatz
wendyluvscatz
Posted 13 Years Ago
Senior Forum Member
Senior Forum Member (12.2K reputation)Senior Forum Member (12.2K reputation)Senior Forum Member (12.2K reputation)Senior Forum Member (12.2K reputation)Senior Forum Member (12.2K reputation)Senior Forum Member (12.2K reputation)Senior Forum Member (12.2K reputation)Senior Forum Member (12.2K reputation)Senior Forum Member (12.2K reputation)
Posts: 2.5K, Visits: 19.4K
saving animated scenes to merge with or use in others is something I wished iClone did too ;)
all my other software suites do.
you can save all the components in non-animated scenes as props by parenting all the components to one item, eg a ground plane
just select them all by holding shift and attach them to the unselected item.
then save it as a prop.
jlittle
jlittle
Posted 13 Years Ago
Posts: 1.9K, Visits: 17.3K
Depends upon what you mean by a complex animation.
For each actor you can save motion clips for custom motions and facial expressions for reuse.
You can save a group of props as a scene which can be loaded in other projects (Note that only one scene can be loaded at a time in a project).
You can group multiple props into a single prop for use in other animations.
You can save the current project as a different project, load that project copy and just modify those elements that need it.
Jeff
torresroberto
torresroberto
Posted 13 Years Ago
Jeff, I believe your CTA videos are the best I have seen in YouTube. Reallusion oughta hire you to do all training videos.
