the rendering produces mute videos
Posted By guidocornia_20100928110210... 14 Years Ago
Posted 13 Years Ago
Posts: 23.1K, Visits: 36.6K
Jeremy_Lawrence (2/13/2013)
Suddenly in a similar boat and going mad.
I have a file from popvideo converter which plays fine in stage mode (IC5) but goes mute on export (into all exportable formats).  Sound from the other characters etc works fine.
When I just import the popvideo into an empty IC5 project it works.  Something in my animation (which has several avatars / cameras / detail) is muting the export.  I've made several popvideo animations and this is the first time I've had such a problem.
Any ideas?
Have you tried opening the project in the 64bit version of iClone5? (if you are using a 64bit operating system). This will eliminate a memory issue with 32bit version.
Jeremy_Lawrence
Jeremy_Lawrence
Posted 13 Years Ago
Veteran Member (533 reputation)Veteran Member (533 reputation)Veteran Member (533 reputation)Veteran Member (533 reputation)Veteran Member (533 reputation)Veteran Member (533 reputation)Veteran Member (533 reputation)Veteran Member (533 reputation)Veteran Member (533 reputation)
Last Active: 6 Years Ago
Posts: 8, Visits: 169
Any ideas?
Posted 14 Years Ago
Posts: 280, Visits: 2.6K
I will put into practice Your suggests.
Thank You, Peter.
Posted 14 Years Ago
Hi Guido
Some things to check to try and eliminate the problem.
1) If you export to video without using .popVideos or other videos in your scene do you get audio?
2) Have you tried exporting to WMV instead of AVI? This will eliminate a possible codec issue.
3) Try using another program to output to video, for example Windows Movie Maker. Do you get sound in the exported video using other software.
4) In addition, check to see if you have updated sound drivers for your computer? Installing these may resolve the issue. You should be able to find them on your computer manufacturers website.
Please give this a try and see if it helps solve the problem.
Posted 14 Years Ago
No solutions, Peter?
G
Posted 14 Years Ago
Thank You for the answer, Peter and sorry for my english. I try to explain my problem.
I do a project with iC5. In a billboard (or a plane A) i put a video. And a character says something. Ok. I look for my work and it's all right.
Now, i export everything, selecting an AVI file.
And the AVI file is completely mute.
And sometimes the final video is without audio also without the billboard or the plane A.
But not even!
I am goin crazy.
Thank You.
Guido.
Posted 14 Years Ago
guidocornia_20100928110210516 (4/16/2012)
Tipically when then i have a plane or a billboard with a video, or when the project exceeds the 500 photograms, i loose the audio in the final video. In AVI format or in WMV format.
Do i something wrong?
Thank You.
Guido
Hi Guido
Do you mean you lose all the audio in the final video or just the audio from the billboard or plane? Also what is Photograms... I don't understand that one I'm afraid.
Posted 14 Years Ago
anybody can help me?
g
Posted 14 Years Ago
Thank You.
Guido
