iClone 5.23 Update - Now Available
Posted By Peter (RL) 12 Years Ago
Posted 12 Years Ago
Posts: 23.1K, Visits: 36.6K
iClone Version History
v5.23 (v5.23.1913.1) released 16th July-12
  • Fixed: Lip-syncing results were not correct; they would sometimes exaggerate expressions.
v5.22 (v5.22.1820.1) released 20th June-12
  • Fixed: Thumbnails disappeared when using the Uploader with data saved in iClone5 64Bit version.
  • Fixed: Using characters converted in 3DX5, would sometimes make the Motion Layer editing crash.
  • Fixed: Motion captured demo project (Gorf Project) would not load in iClone.
  • Fixed: Dragging an image to a path would cause iClone to crash.
v5.21 (v5.21.1627.1 ) released 27th April-12
  • Fixed: Popup message "Raise Left Cheek" crashing under some special conditions.
  • Fixed: Could not reload projects containing particle effects.
  • Fixed: "Terms Of Endearment" & "Argument's Motion pack" content packs were not working properly.
  • Fixed: Device Mocap was not working in 64Bit OS.
v5.2 (v5.2.1613.1 ) released 19th April-12
  • Added: Add 64bit beta version for 64bit OS.
  • **Please Note: In 64Bit version, Export > Video only supports .avi format output.**
  • Added: Allow edit character in 3DXchange5 by clicking "Edit in 3DXchange".
  • Added: Allow add motion to 3DXchange5 by right mouse click "Collect Clip" track.
  • Enhanced: Content update – Character>Chuck
  • Fixed: Stereo output grass was flashing after change wind strength setting on grass.
  • Fixed: Break clip on timeline cause iClone hanging in some condition.
  • Fixed: character shift moved when character link to prop and play the second motion clip.
Please Note: If you wish to try the new 64bit Beta version of iClone 5.2 then you will need to uninstall your current version. Then download the new full installer from your Member Account and install. This will then give you icons for both the 32Bit and 64Bit versions on your Desktop.
Please login to your Member Account to download both the update and latest full installer or use LiveUpdate to get the latest update..
Previous History
v5.13 (v5.13.1523.1) released 23rd March-2012
  • Added: "Reset Scale" to prevent non-uniform scale objects distorting out of shape under some conditions.
    (ex: wheel object on Physics Toolbox)
  • Added: Enable "Set as Dummy" while multi-object selected.
  • Added: Y and Z rotation for Physics-Spring constraint.
  • Enhanced: Allow "Preview Render" to render Dummy Object, Grid and Axial.
  • Fixed: Cannot add action command when Rigid body simulation is turned off.
  • Fixed: Timeline does not auto extend while adding track.
  • Fixed: Hair Scale gizmo axial.
v5.12 (v5.12.1410.1) released 13th February-12
  • Device Mocap (Kinect for Windows): Formal release of Device Mocap MS version for Microsoft Kinect SDK.
  • Added: "Remove Script" function for Projects, iProps, and Characters.
  • Added: Prop with script now appears with blue text in Scene Manager.
  • Fixed: Some iProp with AML script convert to non-human in 3DXchange4, producing incorrect motion in iClone5.
  • Fixed: Issue with opening Facial Puppet Panel.
  • Fixed: Cannot activate physics for props which are converted from a terrain component
v5.11 (v5.11.1320.1) released 20th January-12
•Fixed: Fixed changing body part failure in G3 character.
v5.1 (v5.1.1317.1) released 18th January-12
Device Mocap:
Provide "Microsoft Kinect SDK" Beta2 version.
- Enhanced: Better skeleton recognition, and more stable skeleton signal.
- Added: Wrist Animation.
- Added: Head Animation (Tilting).
- Added: Floor Auto Detection.
•Added: Mirror Function in Mocap control panel.
•Added: Provide Smoother to reduce noise while capturing.
•Added: Floor Calibration to get better foot to floor relation.
•Added: "Body Command" function to control Preview, Record and Stop commands.
Physics Enhancement:
•Added: Multi – Constraint.
•Added: Constraint Stability Setting.
•Added: Hinge Constraint.
•Added: Slider Constraint.
•Added: Point to Point Constraint.
•Added: Generic Constraint.
•Added: Rope Constraint.
•Added: Cone Twist Constraint.
•Added: Spring Constraint.
•Added: Make it keyable for Rigidbody 4 state type.
Others:
•Added: Right click to switch pin state.
•Added: Parent & Local option for Gizmo Rotation.
•Added: Press hotkey W, E, allows looping switch World (Parent) & Local.
•Added: Direct Puppet - Add mirror function.
•Added: Allow use right mouse click to switch Direct Puppet pin state.
•Added: Added tab hotkey to switch to start and end of each clip in the clip track in Timeline.
•Enhanced: Enhanced scene manager performance.
•Enhanced: Dragging Left-Right palm in Motion layer would spread open and close palm.
•Simplified Trial registration flow on Trial version.
•Fixed: Side face image not obvious while creating a face.
•Fixed: Motion Layer - Mirror function not work properly while the character is rotating.
•Fixed: Fixed deformed lag issue after save and reload of some G2 Characters.
•Fixed: Fixed set follow cam to current view and switch camera causes project load failure.
•Fixed: Fixed some object transform value convert failures caused them to appear upside down or disordered.
•Fixed: Fixed system task bar set to left or right causing iClone window to be cropped when maximizing window.
•Fixed: Fixed particle effect always on the front when Toon or Ambient Occlusion effect set to On.
•Fixed: Fixed: Fixed some character loading failure in "Female SuperHeroes" pack.
•Fixed: Fixed "Align Actor Motion" occasional movement error.
You can upgrade to this latest version by running LiveUpdate from your Start Menu/Reallusion or by logging into your Account and choosing Bonus.
Threaded View
Threaded View
Forum Post iClone 5.23 Update - Now Available By Peter (RL) ( 12 Years Ago )
Forum Post NEW UPDATE - iClone 5.12 has now been released (13th February 2012).... By Peter (RL) ( 12 Years Ago )
Forum Post [quote][b]Peter (RL) (2/13/2012)[/b][hr] NEW UPDATE - iClone 5.12 has... By tonilandau ( 12 Years Ago )
Forum Post [quote][b]tonilandau (2/19/2012)[/b][hr][quote][Also what can be done... By Peter (RL) ( 12 Years Ago )
Forum Post NEW UPDATE - iClone 5.13 has now been released (22nd March 2012). By Peter (RL) ( 12 Years Ago )
Forum Post UPDATE - v5.13 (v5.13.1523.1) released 23rd March-12 A new... By Peter (RL) ( 12 Years Ago )
Forum Post SAme to me, anyway which generation I use to animate! Before and after... By Liquid Rock ( 12 Years Ago )
Forum Post That was fast. Bravo, Reallusion. By animatom ( 12 Years Ago )
Forum Post Hi Peter, As of this note, my account still shows version 5.13... By hgagne ( 12 Years Ago )
Forum Post Hi: LiveUpdate is Failing will try downloading Patch from... By power ( 12 Years Ago )
Forum Post I`ve used live update today (24th March) but Iclone is still showing... By Galfridus ( 12 Years Ago )
Forum Post I imagine this is common knowledge - but i haven't seen any mention of... By planetstardragon ( 12 Years Ago )
Forum Post I just got the same message. By paulsulsky ( 12 Years Ago )
Forum Post I downloaded the patch from my account and even though the data says... By animagic ( 12 Years Ago )
Forum Post Thanks Animagic Will give that a try. Geoff. Update 25th March. Now... By Galfridus ( 12 Years Ago )
Forum Post The LiveUpdate version appears not to be updated to the latest build... By Peter (RL) ( 12 Years Ago )
Forum Post iClone 5.2 has now been released. This new upgrade includes the long... By Peter (RL) ( 12 Years Ago )
Forum Post I must be dreaming :w00t: ......Ahhhhh 64bit :D:D:D:D:D By mark ( 12 Years Ago )
Forum Post [quote][b]mark (4/18/2012)[/b][hr]I must be dreaming :w00t:... By Paumanok West ( 12 Years Ago )
Forum Post Will we be able to install both 32-bit and 64-bit versions or do we... By animagic ( 12 Years Ago )
Forum Post [quote][b]animagic (4/18/2012)[/b][hr]Will we be able to install both... By Peter (RL) ( 12 Years Ago )
Forum Post [quote][b]Peter (RL) (4/18/2012)[/b][hr][quote][b]animagic... By Shaky ( 12 Years Ago )
Forum Post Memory. iClone will be capable to address all RAM you have in comp.... By animatom ( 12 Years Ago )
Forum Post [quote][b]animatom (4/18/2012)[/b][hr]Memory. iClone will be capable... By Shaky ( 12 Years Ago )
Forum Post [quote][b]Shaky (4/18/2012)[/b][hr]I have windows 7 (64 bit). Is it... By Peter (RL) ( 12 Years Ago )
Forum Post Great timing. I'll be testing the 64-bit version with a scene I'm... By Keith_MPS ( 12 Years Ago )
Forum Post [quote][b]gnasche (4/18/2012)[/b][hr]Great timing. I'll be testing the... By sjonesdc ( 12 Years Ago )
Forum Post [quote][b]sjonesdc (4/18/2012)[/b][hr]I hate to sound like a "newbie",... By Keith_MPS ( 12 Years Ago )
Forum Post [quote][b]sjonesdc (4/18/2012)[/b][hr]I hate to sound like a "newbie",... By Peter (RL) ( 12 Years Ago )
Forum Post Peter, Thanks!!! By sjonesdc ( 12 Years Ago )
Forum Post Incredible: the world's coolest software gets a 64-bit upgrade--and... By Paumanok West ( 12 Years Ago )
Forum Post Oooo PW! you naughty boy!! My Freudian slip is showin' :P:P:P By mark ( 12 Years Ago )
Forum Post why there is only a AVI Video Exportoption in 64 Bit ??? By RB3006 ( 12 Years Ago )
Forum Post Funny, PW :) Here's what I did. But...I was extremely paranoid... By Keith_MPS ( 12 Years Ago )
Forum Post I created a NEW iCon to replace the 64Bit iCon for iClone5.2 If you... By Cricky ( 12 Years Ago )
Forum Post I just ran the patch on my 64bit beta now characters talk with text... By wendyluvscatz ( 12 Years Ago )
Forum Post Well, I gave up after adding 51 avatars without it crashing.... By Keith_MPS ( 12 Years Ago )
Forum Post No probs here - Yet. All Content previously Copied from iC4 to iC5 32... By colour ( 12 Years Ago )
Forum Post I got the same error, with one test project, in 32 bit mode before; of... By rgreenidge ( 12 Years Ago )
Forum Post Super cool. I am so downloading this today. And tomorrow buying a new... By LarryPlane ( 12 Years Ago )
Forum Post My only gripe (thus far) with the 64 bit version is that the only... By martok2112 ( 12 Years Ago )
Forum Post [quote][b]martok2112 (4/19/2012)[/b][hr]My only gripe (thus far) with... By Peter (RL) ( 12 Years Ago )
Forum Post [quote][b]Peter (RL) (4/19/2012)[/b][hr][quote][b]martok2112... By martok2112 ( 12 Years Ago )
Forum Post I can confirm this on the 64bit version: By LarryPlane ( 12 Years Ago )
Forum Post Same here[quote][b]Paul_Ekert (4/19/2012)[/b][hr]I can confirm this on... By colour ( 12 Years Ago )
Forum Post thxxxxxxxxxxxxxxxxxxxxxxxxxxxxx By SpyWare2 ( 12 Years Ago )
Forum Post Just want to confirm that if I Uninstall my current 32-bit version of... By bobdoyle ( 12 Years Ago )
Forum Post @Bob, you should be fine with uninstall, I did it and still have my... By planetstardragon ( 12 Years Ago )
Forum Post [quote][b]bobdoyle (4/19/2012)[/b][hr]Just want to confirm that if I... By Peter (RL) ( 12 Years Ago )
Forum Post imho, you should always print either uncompressed avi or image... By planetstardragon ( 12 Years Ago )
Forum Post Another bug I've found. 1) add fire torch particle to a scene. 2)... By LarryPlane ( 12 Years Ago )
Forum Post This one really bites! Lost about three hours of work here by saving... By LarryPlane ( 12 Years Ago )
Forum Post [quote][b]Paul_Ekert (4/19/2012)[/b][hr]This one really bites! Lost... By Keith_MPS ( 12 Years Ago )
Forum Post Good suggestion Keith, but not, sadly not. No worries, I'm cool with... By LarryPlane ( 12 Years Ago )
Forum Post Looks like most all particle effects have this project loading... By mark ( 12 Years Ago )
Forum Post Unfortunately there is an issue loading projects containing particles... By Peter (RL) ( 12 Years Ago )
Forum Post Good to know. I guess that's why my 51 avatar project didn't... By Keith_MPS ( 12 Years Ago )
Forum Post the load error come with every Version 5.2 saved projekt... By hj ( 12 Years Ago )
Forum Post Glad to hear the issue is being worked on. So far I'm very happy with... By Keith_MPS ( 12 Years Ago )
Forum Post I'd have to add that after using the new 64bit version all day it does... By LarryPlane ( 12 Years Ago )
Forum Post Pretty sure the folks at RL will nail the bugs soon! But I must... By mark ( 12 Years Ago )
Forum Post Well, I removed the old version and attempted to do a fresh install to... By GimpMedia ( 12 Years Ago )
Forum Post [quote][b]Ratticis (4/19/2012)[/b][hr]Well, I removed the old version... By Rampa ( 12 Years Ago )
Forum Post [quote][b]rampa (4/19/2012)[/b][hr]Ratticis, go into your account on... By Keith_MPS ( 12 Years Ago )
Forum Post Issue (Maybe new): When you add an avatar, it will blink for the... By Keith_MPS ( 12 Years Ago )
Forum Post Ah, thank you. Knew it was probably a simple fix, but sometimes (ok,... By GimpMedia ( 12 Years Ago )
Forum Post Have problems opening new project that I just saved last night with... By Cellygon ( 12 Years Ago )
Forum Post [quote][b]Cypher Wolf (4/20/2012)[/b][hr]Have problems opening new... By LarryPlane ( 12 Years Ago )
Forum Post [quote][b]Paul_Ekert (4/20/2012)[/b][hr][quote][b]Cypher Wolf... By Cellygon ( 12 Years Ago )
Forum Post Will we get AVCHD format with the final release ? It is the most... By RobertoColombo ( 12 Years Ago )
Forum Post [quote] Have problems opening new project that I just saved last... By Postfrosch ( 12 Years Ago )
Forum Post I stand to be corrected, however, IMO, AVCHD isn't an Export File... By colour ( 12 Years Ago )
Forum Post [quote][b]colour (4/20/2012)[/b][hr]I stand to be corrected, however,... By LarryPlane ( 12 Years Ago )
Forum Post [quote][b]Paul_Ekert (4/20/2012)[/b][hr][quote][b]colour... By animagic ( 12 Years Ago )
Forum Post Another little glitch I'm noticing is that cameras do not come up in... By martok2112 ( 12 Years Ago )
Forum Post [quote][b]martok2112 (4/20/2012)[/b][hr]Another little glitch I'm... By LarryPlane ( 12 Years Ago )
Forum Post [quote][b]Paul_Ekert (4/20/2012)[/b][hr][quote][b]martok2112... By martok2112 ( 12 Years Ago )
Forum Post [quote][b]martok2112 (4/20/2012)[/b][hr][quote][b]Paul_Ekert... By LarryPlane ( 12 Years Ago )
Forum Post Peter (RL) did state earlier that the particle problem was being... By martok2112 ( 12 Years Ago )
Forum Post Ok....now for some points I've found, both good and bad, with the 64... By martok2112 ( 12 Years Ago )
Forum Post Same here. Cameras show up in 64bit timeline Keyframes and all :) By mark ( 12 Years Ago )
Forum Post Hi Everyone We have now issued a temporary fix for the issue that... By Peter (RL) ( 12 Years Ago )
Forum Post Wow! I am a conservative teacher and I always warn students from... By Apparition ( 12 Years Ago )
Forum Post Mike, it's just the fun of trying... Experiment, right? By animagic ( 12 Years Ago )
Forum Post I am just happy to be able to add bump to my all surfaces without... By wendyluvscatz ( 12 Years Ago )
Forum Post [quote][b]Peter (RL) (1/21/2012)[/b][hr] iClone Version History... By hgagne ( 12 Years Ago )
Forum Post Here are the answers to your questions. :) [quote][b]hgagne... By Peter (RL) ( 12 Years Ago )
Forum Post You should not need to reinstall your content. Peter recommended in... By animagic ( 12 Years Ago )
Forum Post Just a quick reminder. If you are having any problems that are... By Peter (RL) ( 12 Years Ago )
Forum Post New 5.21 update released today. Please download from your Member... By Peter (RL) ( 12 Years Ago )
Forum Post [quote][b]Peter (RL) (4/30/2012)[/b][hr]New 5.21 update released... By Cricky ( 12 Years Ago )
Forum Post [quote][b]Cricky (4/30/2012)[/b][hr]The [i][u]Raise Left Cheek[/u][/i]... By Peter (RL) ( 12 Years Ago )
Forum Post thank you.My timeline is back :) By muratcizer ( 12 Years Ago )
Forum Post hi, after updating my timeline window dissapeared.Cant get it back.I... By muratcizer ( 12 Years Ago )
Forum Post [quote][b]muratcizer (4/30/2012)[/b][hr]hi, after updating my timeline... By Peter (RL) ( 12 Years Ago )
Forum Post I was glad to see 5.21 update and installed. Since I updated to 5.2 I... By rfacko ( 12 Years Ago )
Forum Post [quote][b]rfacko (4/30/2012)[/b][hr]I was glad to see 5.21 update and... By hgagne ( 12 Years Ago )
Forum Post Hi, Hgagne: That is a thorough response with much information. I'll... By rfacko ( 12 Years Ago )
Forum Post Hi, hgagne I followed all of the steps involved, unplugged,... By rfacko ( 12 Years Ago )
Forum Post [quote][b]rfacko (5/1/2012)[/b][hr]Hi, hgagne I followed all of the... By hgagne ( 12 Years Ago )
Forum Post Gulp! I'll slowly try to cover all of those bases. You are a true... By rfacko ( 12 Years Ago )
Forum Post v5.22 (v5.22.1820.1) released 20th June-12 Fixed: Thumbnails... By Peter (RL) ( 12 Years Ago )
Forum Post v5.23 (v5.23.1913.1) released 16th July-12 Fixed: Lip-syncing... By Peter (RL) ( 12 Years Ago )
Forum Post Hi. After reading about all the issues with the 5.2 versions and the... By majorlance ( 12 Years Ago )
Forum Post [quote][b]majorlance (7/24/2012)[/b][hr]Hi. After reading about all... By Peter (RL) ( 12 Years Ago )
Forum Post Quote; (I get the usual Error Message gibberrish, when using BB Code):... By colour ( 12 Years Ago )
Forum Post No other export file format yet for the 64 bits version ? :doze: ... By RobertoColombo ( 12 Years Ago )
Forum Post Peter, thanks for the announcement. But I am still slightly confused... By tonilandau ( 12 Years Ago )
Forum Post [quote][b]tonilandau (7/24/2012)[/b][hr]Peter, thanks for the... By Peter (RL) ( 12 Years Ago )
Forum Post Okay Peter, there seem to be no complaints after 5.23 so I'm taking... By majorlance ( 12 Years Ago )
Forum Post Just updated, but the version reads as 5.2.1618.1. Do I just go... By majorlance ( 12 Years Ago )
Forum Post Never mind; I updated again, and it went to 5.23. Sorry I couldn't... By majorlance ( 12 Years Ago )
Forum Post Dear users, Thanks for your feedback for the new patch. ... By Bruce (RL) ( 12 Years Ago )
Forum Post sw00000p, did you update to 5.31 first before applying the patch in... By animagic ( 12 Years Ago )
Forum Post @swoooop Make it real !!! First analyse... and study !!! Then... By RobertoColombo ( 12 Years Ago )
Forum Post Can we just go ahead and overwrite the exe. files not having done the... By mark ( 12 Years Ago )
Forum Post This Screenshot Error Message is what I get for both iC5 Bin & iC5 Bin... By colour ( 12 Years Ago )
Forum Post .................And - Since I can't Edit my Post above............. By colour ( 12 Years Ago )
Forum Post I just copied and replacred the bin 32 and 64 files in my program... By wendyluvscatz ( 12 Years Ago )
Forum Post Haven't installed yet... but I not sure I'm in the same category as... By mark ( 12 Years Ago )
Forum Post I feel almost guilty, having so few problems myself...:ermm: By animagic ( 12 Years Ago )
Forum Post I´m sorry, but if someone is not able to unzip a file and copy two... By moviemaker100 ( 12 Years Ago )
Forum Post Well it looks like the install went very well on this end...so far at... By mark ( 12 Years Ago )
