bg38
Visits: 911
I'm using the trial copy of 3dxchange, and had constructed a prop from several primitives in iclone 5 pro, attached them all ,then saved said item in iclone as one prop. I then reloaded the same prop into the scene to see how it loads. All is well here so far. I wanted to export it to 3dxchange and work on it outside of iclone but I get a 'file import error' pop up. Should i just use one primitive, export it to 3dxchange then work on it, import it back into iclone then finish building my prop ? I wasn't sure if I was trying to export too many primitives at once even tho I had saved them all as one prop. Everything else I've done in 3dxchange has worked great , save for one particular model i tried opening but found it was waaaay too large EDIT: Answered my own question just now. i tried exporting just one primitive alone and got the same result. file import error from 3dxchange. Are iclone primitives not usable in the program?
12 Years Ago by
bg38
Sen
Posts: 2.8K,
Visits: 28.5K
Hi , 3dxchange 4 no work with iclone 5
CGTRADER
bg38
Visits: 911
ahhh. ok. It will let me import sketchup models from 3dxchange into iclone 5, but not export stuff out of iclone, correct? Cause i have a few models I successfully imported from sketchup into iclone 5 with 3dxchange. glad I found this out now, I was on the edge of buying 3dxchange, but will have to wait until it is compatible with iclone pro 5 thank you for your help sen edit : that has to be it. I imported another custom prop successfully in a matter of seconds, but it won't do an iclone 5 standard prop
12 Years Ago by
bg38
Apparition
Apparition
Posted 12 Years Ago
Last Active: 8 Years Ago
Posts: 2.2K,
Visits: 4.0K
Sen is right! If you want to do 3DX operations you need iCLone4, but I guess not for long. Surely the genius staff at Reallusion is working hard to have 3DX5 ready for us!
Mike Aparicio-Reallusion Certified Innovative Content Developer
Posted 12 Years Ago
Posts: 23.1K,
Visits: 36.4K
bg38 (1/8/2012)
ahhh. ok. It will let me import sketchup models from 3dxchange into iclone 5, but not export stuff out of iclone, correct? Cause i have a few models I successfully imported from sketchup into iclone 5 with 3dxchange. glad I found this out now, I was on the edge of buying 3dxchange, but will have to wait until it is compatible with iclone pro 5 thank you for your help sen edit : that has to be it. I imported another custom prop successfully in a matter of seconds, but it won't do an iclone 5 standard prop The pipeline from 3DXchange > iClone5 will work perfectly but not iClone5 > 3DXchange4. This is because 3DXchange4 does not support IC5 file data. A new version of 3DXchange is in development and this will be fully compatible with iClone5.
bg38
Visits: 911
thanks for the reply everyone. I found that out about the import export deal between the 3 programs. just wondering tho, any ideas yet on how much to update from 3dxchange 4 to 5?
Posted 12 Years Ago
Posts: 23.1K,
Visits: 36.4K
No details on upgrade pricing yet but it will be very competitive as always.
hassan06
hassan06
Visits: 17
i am currently using iclone 6 pro when i am trying to importing my .iproject animated model it says 3DXchange 6 may not support that format? kindly any solution?
Posts: 5.7K,
Visits: 26.4K
3DXchange can not import/open an iProject. It can only import/open iProp, iAcc and iAvatar files from iClone.
SirWill
SirWill
Visits: 8
wires (7/13/2016) 3DXchange can not import/open an iProject. It can only import/open iProp, iAcc and iAvatar files from iClone.I have notices the same when trying to import using blender and your character you have rigged using rigify it brings the same message. Anybody with a solution?
