3dxchange file import error
Posted By bg38 14 Years Ago
bg38
bg38
Posted 14 Years Ago
Last Active: 7 Years Ago
Posts: 117, Visits: 911
I'm using the trial copy of 3dxchange, and had constructed a prop from several primitives in iclone 5 pro, attached them all ,then saved said item in iclone as one prop. I then reloaded the same prop into the scene to see how it loads.
All is well here so far. I wanted to export it to 3dxchange and work on it outside of iclone but I get a 'file import error' pop up.
Should i just use one primitive, export it to 3dxchange then work on it, import it back into iclone then finish building my prop ?
I wasn't sure if I was trying to export too many primitives at once even tho I had saved them all as one prop.
Everything else I've done in 3dxchange has worked great , save for one particular model i tried opening but found it was waaaay too large ;)
EDIT: Answered my own question just now. i tried exporting just one primitive alone and got the same result. file import error from 3dxchange. Are iclone primitives not usable in the program?
Photobucket
