Insufficient Disk Space Message
Posted By brothertcoleman 15 Years Ago
brothertcoleman
brothertcoleman
Posted 15 Years Ago
Posts: 578, Visits: 6.1K
I have sufficient disk space .This only happens only when I try to load one of my larger projects,this is strange because it loaded fine last night.Is there a way to recover my project because I put a lot of detail into it?
Thanks Tim
brothertcoleman
brothertcoleman
Posted 15 Years Ago
I got it to work now.
My work around;
Okay I just discard the insufficent disk space message and don't touch anything,if I mouse click or anything the program will crash.
If I let it sit on the screen below the project will eventually load.
 I convert the project to a video then import the video back into CTA(prop) as a new project and add whatever I want to it without slowing down CTA.
Posted 15 Years Ago
Posts: 23.1K, Visits: 36.6K
Hi..BC
I think the error message is a little misleading and most likely the problem is the size of the project file which is very large. Perhaps you could try streamlining the project to reduce the size. You may have one or two elements that are extremely large that could be reduced in size or possibly removed altogether. A little trial and error will most likely identify the problem elements.
If you still continue to have problems then please contact Tech Support using the link below. They will be able to advise you on how best to resolve this issue.
http://www.reallusion.com/CustomerSupport/User/QForm.aspx
